12 vdc 7.5a switching supply
CAT# PS-1275 $27.00 each it is alittle $$$$$$$$$$
http://www.allelectronics.com/make-a-store/item/PS-1275/12-VDC-7.5A-SWITCHING-SUPPLY/1.html
The only thing
I cut off the strange coax barrel connector (used for medical equipment apparently) The cable is 3 conductor coax. The outer shield is (-). The inner shield is (+). The center conductor is outlet ground which I did not use .
What is also nice about this power supply is that it check the output for a short meaning that it has power but when you put a load on it shut down for five seconds and power back up again
I am using to power my four out side cameras around my house it works real good for this
I am thinking about buy another one of these power supply to use in a project
The only thing
Man the price of theses little guys has really gone up.It is a really clean supply though
Better bundle up,Its suppose to be in the teens here in the morning. I'm 45 miles east of Tampa. Its really gonna be cold in J-ville
This morning when I left for work,about 05:30. All of the orange tress had icicles hanging under their branches from the mister waterer's.When I returned home at 16:30 the icicles were still there. I live in sunny Central Florida not icy Florida.
I thought that Florida was not supost to this c..oooooooooooo..ld what happen here
