BS2 burnout? — Parallax Forums
BS2 burnout?
bytedude1bytedude1 Posts: 9
edited 2010-12-12 18:08 in BASIC Stamp
Hey guys, listen my bs2 will not output any voltage on I/O pin 4 could someone help. I've checked everything,
my program, connections, and nothing happens. I even checked it with a volt meter and there was nothing coming out. : I
  • LeonLeon Posts: 7,620
    edited 2010-12-12 12:50
    If the other pins work OK, it is probably damaged.
    edited 2010-12-12 13:19
    If you're trying to draw too much current from I/O pin 4, you may not see normal voltages there. Any time you have a question like this, you really have to supply a schematic showing how everything is connected and you have to supply a copy of your program. Otherwise, we can't help you other than with very general suggestions.
    edited 2010-12-12 14:53
    Even a brief overcurrent (short circuit) can permanently damage an output pin, never to work as an output again. It MAY still function properly as an input, depending on the particular damage it went through. If so, you can swap a few pins around (using pin4 as an input) and not lose any functionality.
  • $WMc%$WMc% Posts: 1,884
    Take a look at current limiting resisters.
    This will help save the rest of your I/O pins
    Take a look at experiment # 14 in the StampWorks Manuel pg. 94
    This shows a use of the resisters
    heres the link for StampWorks
    http://www.parallax.com/Portals/0/Downloads/docs/books/sw/Web-SW-v2.1.pdf
