What code should I use?
I have bought a Pob-Grip, to see it,:
http://www.generationrobots.com/pob-grip-robots-pob-technology,us,4,POB-Grip.cfm
I would like too put it on my boe bot, but what code should I use?
I use Bs2.
I use Bs2.
From what I can see from the link you supplied, the Pob-Grip uses two standard servos. Look in the "Robotics with the BoeBot" tutorial for examples of servo control. You will have to develop your own code based on that. Use the examples in the tutorial to experiment with the Pob-Grip to see what happens when each of the servos is moved.
But I know how to control the servos, but not sensor who is with the pob grip.
