Simple test or demo for audio? — Parallax Forums
Dan EDan E Posts: 61
edited 2010-12-11 21:59 in Propeller 1
Hi, I am trying to write an object that plays a WAV file from a SD card through a speaker attached to an audio power amplifier. As of right now, no sound comes out and I am trying to debug it. My amplifier circuit is pretty simple so I don't think that is the problem, so I figure it must be the pin assignments I used and/or I improperly used the OBEX code.
Is there a simple audio object or demo with pin assignments that could be used to help debug this problem? I would like to see if in fact it is my speaker, power amp circuit, pin assignment, or how I call up the file possibly, and learn how to properly execute this program.
I tried to use the wavePlayerSD and its included objects, although I could not see where I assign the pins I am using, and I am using just one speaker, it seems that that code and others are for 2 speakers.
Dan E
    edited 2010-12-11 09:46
    Here is a quick and dirty audio diagnostic I use for my boards:
    ' Quick&Dirty Audio diagnostic for PropCade @ Mikronauts.com
    pub audio_diag(pin)|f,q
      dira[pin]~~
      repeat f from 0 to 500
        repeat 10
          outa[pin]~~
          repeat f
          outa[pin]~
          repeat f
      repeat f from 500 to 0
        repeat 10
          outa[pin]~~
          repeat f
          outa[pin]~
          repeat f
  • RaymanRayman Posts: 16,313
    edited 2010-12-11 09:52
    I have a wav player in OBEX that plays an embedded file, so no SD card required...
  • Dan EDan E Posts: 61
    edited 2010-12-11 09:53
    Thanks, I'll try it out.
    edited 2010-12-11 12:15
    Dan E: I noticed on the other thread you mentioned it was a 16 ohm speaker amplifier. What you require is an amplifier that works with an iPod equivalent (i.e. takes earphones as inputs). Is this what you have?
    edited 2010-12-11 17:56
    Yes, it's actually a requires a stereo audio cable, but I cut the cord so that I could wire it to my audio output pin, only to reveal there are 3 wires, red, black and blue.
    I assume red is for power, black for ground, leaving blue as the input, but the device already has a 9volt supply, so I'm a little puzzled,
    My ipod headphone jack is a little smaller, than this cord, but maybe I can find a better match at radio shack.
    edited 2010-12-11 17:59
    Hey Dan,
    Just a quick caution. If you are using headphones to the Propeller, do a quick test to make sure that the output is at a safe level for your ears. I've gotten some unregulated audio from my Propeller that really smarted.
    OBC
    edited 2010-12-11 18:01
    Actually, I just checked, and you're right, it is wxactly the same as my ipod headphones, still puzzled as to the correct connection for the 3 wires though.
    edited 2010-12-11 18:03
    will do, the device I have is a mini amplifier speaker from radioshack, luckily with a volume control.
    Figured out what the 3 wires were by cutting apart my ipod headphones, and the stereo audio jack.
    Although the cable i bought had a jack on each end, the wiring was for a right and left speaker or headphone, which corresponded to the wiring of my ipod headphones, and the other wire was soldered to the isolated ground of the jack.
