Ir remote controlled Scribbler2
Ok - now that I have a S2, here is my very simple program to move your S2 around using a compatible Sony tv remote menu arrow buttons. This is a very simple program that only uses the S2's 38khz ir obstacle detector for an ir receiver and the S2's wheel motors. I commented the code.
Con 'simple scribbler2 sony tv ir remote control program by David Ratcliff "ratronic" 12/9/11
_clkmode = xtal1 + pll16x 'set up clock for s2 @ 80mhz (5mhz crystal * 16pll)
_xinfreq = 5_000_000 '
Var
long irc 'irc = sony ir tv remote control code # for button being pressed
'or irc = 255 if no button is being pressed
Obj
ir : "irtest" 'sony ir tv remote decoder object
s2 : "s2" 'scribbler2 object
Pub main
s2.start 'start s2 object
s2.start_motors 'start s2 motors
ir.start(s2#obs_rx, @irc) 'start sony ir tv remote decoder object using s2 obstacle detector for ir receiver
s2.set_speed(15) 'set scribbler2 moving speed, can be set from 0=stop to 15=full speed)
repeat
if irc == 116 'arrow-up button move s2 forward
s2.go_forward(1)
if irc == 117 'arrow-down button move s2 in reverse
s2.go_back(1)
if irc == 52 'arrow-left button turn s2 left
s2.turn_by_deg(1)
if irc == 51 'arrow-right button turn s2 right
s2.turn_by_deg(-1)
if irc == 255 'no button on remote being pressed s2 stop
s2.wait_stop
