RFID and the SX
I am working on a project that will help me get the ID number of each of the tags that I get in without using a computer. The device will be hand held with a 2 line 16 digit display to show me the RFID key ID. For some reason, I am not able to get the correct A-F and 0-9 characters to be displayed on the screen. I get strange characters.
Here is my code :
Here is my code :
DEVICE SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ 4_000_000
ID "RFID"
LcdTx VAR RA.2 ' LCD serial connection
RfidEn VAR RA.1 ' RFID enable control
RfidRx VAR RA.0 ' RFID serial input
Lock VAR RB.0 ' lock control
TagMax CON 2 ' three tags, (0 - 2)
LcdBaud CON "T19200" ' or T2400, or T9600
RfidBaud CON "T2400"
LcdBkSpc CON $08 ' move cursor left
LcdRt CON $09 ' move cursor right
LcdLF CON $0A ' move cursor down 1 line
LcdCls CON $0C ' clear LCD (need 5 ms delay)
LcdCR CON $0D ' move pos 0 of next line
LcdBLon CON $11 ' backlight on
LcdBLoff CON $12 ' backlight off
LcdOff CON $15 ' LCD off
LcdOn1 CON $16 ' LCD on; no crsr, no blink
LcdOn2 CON $17 ' LCD on; no crsr, blink on
LcdOn3 CON $18 ' LCD on; crsr on, no blink
LcdOn4 CON $19 ' LCD on; crsr on, blink on
LcdLine1 CON $80 ' move to line 1, column 0
LcdLine2 CON $94 ' move to line 2, column 0
Active CON 0 ' for RFID reader
Deactivated CON 1
Open CON 1 ' for lock
Closed CON 0
' Variables
idx1 VAR Byte ' loop control
idx2 VAR Byte
char VAR Byte
tagBuf VAR Byte(10) ' tag bytes from reader
tagNum VAR Byte(10) ' tag number
offset VAR Byte
tmpB1 VAR Byte ' subroutine work vars
tmpB2 VAR Byte
tmpB3 VAR Byte
tmpW1 VAR Word
WATCH char
WATCH tagBuf(0)
WATCH tagBuf(1)
WATCH tagBuf(2)
WATCH tagBuf(3)
WATCH tagBuf(4)
WATCH tagBuf(5)
WATCH tagBuf(6)
WATCH tagBuf(7)
WATCH tagBuf(8)
WATCH tagBuf(9)
PROGRAM Start
' Subroutine Declarations
DELAY SUB 1, 2 ' delay in milliseconds
LCD_OUT SUB 1, 2 ' byte or string to LCD
CLEAR_LCD SUB 0 ' clear LCD, BL is on
RX_RFID SUB 0 ' get char from RFID
' Program Code
Start:
PLP_B = %00000001 ' pull up unused pins
PLP_C = %00000000
RA = %0011 ' disable reader, lock it up
TRIS_A = %0100
Main:
CLEAR_LCD
LCD_OUT "Present ID."
LCD_OUT LcdLine2
LCD_OUT LcdOn2 ' flash block cursor
Get_Tag:
RfidEn = Active
DO
char = RX_RFID
LOOP UNTIL char = $0A ' wait for header
FOR idx1 = 0 TO 9 ' get RFID bytes
tagBuf(idx1) = RX_RFID
FOR idx2 = 0 TO 15 ' loop through characters
READ Tags + idx2, char ' read tag character
IF char = tagBuf(idx1) THEN
LCD_OUT char
ENDIF
NEXT
break
NEXT
RfidEn = Deactivated
DELAY 1000
GOTO Main
DELAY:
IF __PARAMCNT = 1 THEN
tmpW1 = __PARAM1 ' save byte value
ELSE
tmpW1 = __WPARAM12 ' save word value
ENDIF
PAUSE tmpW1
RETURN
LCD_OUT:
tmpB1 = __PARAM1 ' byte or string offset
IF __PARAMCNT = 2 THEN ' string specified?
tmpB2 = __PARAM2 ' yes, save base
DO
READ tmpB2 + tmpB1, tmpB3 ' read a character
IF tmpB3 = 0 THEN EXIT ' if 0, string complete
SEROUT LcdTx, LcdBaud, tmpB3 ' send the byte
INC tmpB1 ' point to next character
tmpB2 = tmpB2 + Z ' update base on overflow
LOOP
ELSE
SEROUT LcdTx, LcdBaud, tmpB1 ' send the byte
ENDIF
RETURN
CLEAR_LCD:
LCD_OUT LcdBLon ' backlight on
LCD_OUT LcdOn1 ' no cursor or blink
LCD_OUT LcdCls ' clear the LCD
DELAY 5
RETURN
RX_RFID:
SERIN RfidRx, RfidBaud, tmpB1
RETURN tmpB1
Tags:
DATA "ABCDEF0123456789"
