Connecting PIR to ADI Ocelot
Good evening Folks,
I apologize for some of my questions as they will certainly reveal my lack of expertize and knowledge in this field.
So lets go, I am trying to connect a PIR to my ADI Ocelot, SECU 16, card.
The SECU 16 is a configurable 8 input, which can be either, 8 Supervised input ( On/Off ) , 4 to 20 mA input or Analog input and 8 output.
Normally I would connect any On/Off type device like a switch,1 wire to an input and the other wire to ground this thrue a 1k Ohm resistor.
How can I connect the PIR since it only has 1 output wire.
Thanks for your assistance.
Regards
Confused Dom:nerd:
Regards
Confused Dom:nerd:
I think I understand.
I guess all these types of sensors weither they be motion, temperature or light intensity only provide logic hi or lo, depending on their state, in order for them to act as a switching device a transistor is required.
You mention the 2N2222, is this type of transistor available in a chip type package where you may have several 2N2222 in one package.
Thanks guys,
Dom:nerd:
The following is a brief overview of the SECU 16, if you are interested in finding out more, this is their site address : www.appdig.com/
Introduction
The SECU-16 module allows 8 inputs and 8 low-current relay outputs to be added to an ADICON control system. The inputs may be supervised (switch closure), analog, or 4-20mA.
Specifications
Power: Input Voltage 9 - 12V DC or AC
Input Current Max 200mA
Inputs: 8 2-wire inputs, Analog (0 5VDC) or Supervised
Outputs: 8 Relay outputs 24VDC, 0.5 Amp
Dimensions: 5.5W x 3.25L x 1.38D
Operating
Temperature: 0ºC to 70ºC
Setup
Remove the SECU-16 top cover.
Connect the power supply to the two screw terminals labeled POWER.
Connect the COM A and COM B terminals to the ADICON bus (see Figure 1).
Figure 1. Typical Wiring Diagram
Three types of inputs may be used on the SECU-16, supervised, analog, and 4-20mA. A supervised input is a passive, non-current supplying input such as a relay or switch. An analog input provides a varying voltage such as a light sensor. Input types are controlled by the jumpers as shown Table 1.
Jumpers P2 P9 control the type if inputs used. P2 controls input 1, P3 controls input2, etc.
Input Type
P2 P9
Supervised
2-3
4-20mA
1-2
Analog
Off
Table 1. Jumper Settings
Jumper 1&2 Jumper 2 & 3 No Jumper
To use an input as a supervised input a 1K Ohm resistor (supplied) must be placed across the input as shown in Figure 2.
The reason I am looking for several NPN 2N2222 in a single package is because I have purchased several motion detectors and light sensors which will all require to be mounted.
Thanks Mike for your assistance.
Dom:nerd:
Look in the DigiKey or Mouser on-line catalogs for reed relays and see what's available with a 5V coil.
Further to your recent response, I was able to locate a schematics from Scary Terry, showing an assembly where the Parallax PIR was used.
Is the following pretty much what you had in mind, the RLY-470 needs to be replaced since it is no longer available, I could use a reed relay instead, I found one with a 10 mA required current with built in diode.
Does all this make sense, I would'nt no better.
Dom
To you and your family.
Merry Xmass and Happy New-Year.
Dom from Canada eh!
