PASM - Averaging Bytes within Longs
lanternfish
What I need to do is average the same byte within two longs e.g. (byte 0 (bits 0 - 7) of long 1 + byte 0 (bits 0 - 7) of long 2)/2
Attached is some code that works so my question is Can it be done more efficiently?
My maths brain is missing a few neurons at the moment so any pointer in a better direction will be most appreciated.
{{Average Bytes within 2 Longs}}
Data Format: Long1 %00000000_00rrrrrr_00gggggg_00bbbbbb
Long2 %00000000_00rrrrrr_00gggggg_00bbbbbb
Answer1 %00000000_00rrrrrr_00gggggg_00bbbbbb
Byte 3 Byte 2 Byte 1 Byte 0
PUB Main
{Launch COG}
coginit(0, @AverageRGB, 0) 'Launch COG 0
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
DAT
org 0
AverageRGB
mov Answer1, #0 'Clear Answer Long
mov RGB1, PseudoIna '1st RGB Value
mov RGB2, PseudoInb '2nd RGB Value
add Answer1, RGB1 'Add RGB Values
add Answer1, RGB2
mov RedValue, Answer1 'To get Red level (byte 2),
and RedValue, RedMask 'Mask of bytes 3,1,0
shr RedValue, #17 'To average Red value shift into lowest byte of long
shl RedValue, #16 'plus one more bit. And then shift back to byte 2
mov GreenValue, Answer1 'To get Green level (byte 1),
and GreenValue, GreenMask 'Mask of bytes 3,2,0
shr GreenValue, #9 'To average Green value shift right lowest byte of long
shl GreenValue, #8 'plus one more bit. And then shift back to byte 1
mov BlueValue, Answer1 'To get Blue level (byte 0),
and BlueValue, BlueMask 'Mask of bytes 3,2,1
shr BlueValue, #1 'To average Blue value shift right one bit
add Answer1, RedValue 'Add Red, Green & Blue Values
add Answer1, BlueValue 'to get
add Answer1, GreenValue
ForeverLoop jmp #ForeverLoop
{Variables}
RGB1 long 0
RGB2 long 0
Answer1 long 0
RedValue long 0
GreenValue long 0
BlueValue long 0
{Constants}
PseudoIna long %00000000_00000000_00001111_00111111
PseudoInb long %00000000_00111111_00110000_00000000
RedMask long $00_FF_00_00
GreenMask long $00_00_FF_00
BlueMask long $00_00_00_FF
DAT mov temp, RGB1 ' keep RGB1 add temp, RGB2 ' RGB1 + RGB2 shr temp, #1 ' (RGB1 + RGB2)/2 and temp, mask ' clean up mask long %00000000_00111111_00111111_00111111Edit: One reason (for me) to delete a post (now being redundant). And you can't **** do it any more.
Thanks so much for that. I knew I was making it more difficult than it needed to be - the obvious was staring me in the face.
