Varable name with cogid
hi!
i want to start a task on several cogs in parallel and make them use var1,var2 etc
now "cogid" is not recognized if i write "varcogid"
how can i solve this?(hope its not needed on compile time because i wanted to write one PUB for all cogs)
greetings
user
greetings
user
CON ccnt = 4 VAR long storage[8] long stack[16*ccnt] PUB null | idx idx := 0 repeat ccnt cognew(method, @stack[16*idx++]) PRI method | private private := storage[cogid]It starts 4 cogs each of which uses a private slot in the storage array.hmh yes thats good my concept is:
one "master" cog
several worker cods that do exactly the same thing
now every worker cog gets its global variable with number 1-7 where it puts the results that cog0 needs for doing its own work based on the results the other cogs deliver
i could use the bunch of longs for doing this, thank you!
also good hint, thanks
i will test both methods since its a first test code
