Does anyone have a gerber file with qfn44 lands?
Hi everybody, I just bought some CAD software from a company called Pentalogic, and would like to design a circuit board for the QFN44 Propeller chip.
Designing the land pattern by hand with the software would be super tedious, and I was wondering if anyone could give me a gerber file of the land pattern.
I just purchased a program called Viewmate Deluxe and I am standing at the bottom of the learning curve.
I don't doubt Leon's assertion that this could be done quickly by someone who is familiar with the software, but I am currently trying to figure out how to generate a blank circuit board with it and have projects in mind that would ideally be done by Christmas.
The software seems incapable of handling the .dip file in the propstick documentation, but claims it can import gerber files.
The reason I want to use a QFN44 is that the project is a piece of electronic jewelery with the propeller controlling some LEDs. Size is an issue with this kind of thing because gaudiness scales directly with size.
Any help you can offer will be greatly appreciated.
I use Viewmate all the time to inspect Gerbers before sending to the board house, but it's not meant for PCB design - it's really for DFM / DRC checking & light editing. Theoretically, you could design a board with it, but it would be very, very painful. I suggest you try something like diptrace, it has a library of footprints including the propeller.
Also, a gerber file only contains info on a single layer - for a prop QFN, you'll likely need several gerbers, copper, mask, and paste. Design software handles this automatically, but Viewmate won't.
Agh, I just paid $95 for this program hoping to use it to design circuit boards.
The good news is that it came with a coupon for $95 off my first order of boards, so it isn't really a loss as long as I can get something done before the 45 day expiration date.
I will check out the freeware version of Diptrace when I get home.
I use an old professional layout program "Protel 3.0" which is around 1995. It was expensive at the time and has become much moreso with time and revisions. However, it suits my needs as I no longer layout pcbs professionally. I have never tried DipTrace but I did try another free layout program which has a schematic program as well (cannot recall it's name -senior moment! - camr from a pcb supplier). It was just OK for small jobs - a bit wierd to use but certainly ok for hobbyists. If you want, I can look on my other laptop for its name - it's quite common.
The free version of Diptrace is very restrictive, on pin count.
How critical is it to ground the center plane on the QFN Propeller?
The pin count is only about 150 on this one, so the freeware Diptrace should work.
If I like the software and want to build more complicated things then I will pony up the cash.
