1302 vs 1307? — Parallax Forums
1302 vs 1307?
cavelambcavelamb Posts: 724
edited 2011-01-22 10:55 in Propeller 1
I'm collecting parts for my Proto board and wanted to ask those who know if there is a preference for
the real time clock chip? Parralax stocks the 1302, but most examples I've seen are for the 1307.
Are they code compatible?
Any serious differences?
Richard
    edited 2010-12-05 23:32
    Apparently they are NOT the same.
    http://www.8051projects.net/forum-t8997.html
    You can Google 'DS1302 versus DS1307' for more discussions.
    Personally, I would use the 1-wire I-Button RTO unit as it has an internal battery that is supposed to provide 10 years service and uses only one pin for i/o.
  • TubularTubular Posts: 4,744
    edited 2010-12-06 00:39
    Don't forget to consider the DS1337, which is 3v3 compatible.
  • Nick McClickNick McClick Posts: 1,003
    edited 2010-12-06 01:16
    @loopy, the DS1307 is i2c, so it uses the same pins your EEPROM are already using.
    Both the 1307 & 1337 are 3.3v compatible (i2c is open drain). The 1307 requires 5v vcc, but that's no problem with the Protoboard.
  • Kal_ZakkathKal_Zakkath Posts: 72
    edited 2010-12-06 12:42
    I've used the 1338, which is similar to the 1337 (but with a batt backup pin and only one alarm, also doesn't come in DIP8 sadly)
    As for code compatibility - I can't speak for 1302-1307, but for the 1338 I took Kye's 1307 driver and modified it.
    Obivoulsy the I2C commands are the same, but the RAM addresses and control registers are different.
  • Jay B. HarlowJay B. Harlow Posts: 79
    edited 2010-12-06 15:39
    The 1302 is not code compatible with the 1307. I recently took Kye's 1307 driver and modified it for 1302. As I finally finished by SD card adapter over Thanksgiving. I'm using the 1302 that is built into Parallax's Propeller Professional Development Board.
    Basically I took code from one of the OBEX 1302 objects and adopted it to Kye's 1307 interface.
    I need to go back and add support for burst mode. I dropped it just to get the code to work...
    Jay
  • cavelambcavelamb Posts: 724
    edited 2010-12-06 17:21
    Thanks for the info, guys.
    One of my intended projects is a "ships bell" function.
    So a custom board will be used in the end.
    Not needing the 5v supply might be a plus.
    I'll dig into the 1338 as well.
  • bpragerbprager Posts: 22
    edited 2011-01-03 07:47
    I am currently trying to use Kye's SD code and have the PPDB. Could you possibly post your modded code? That way I could at least get started learning the object while I figure out what to do next.
    Thanks for your consideration.
    Bruce Prager
    bprager wrote: »
    Bruce Prager
    Here's my modified code "as is"
    ''│ DS1302 Real Time Clock Engine        │
    ''│ Author: Jay B. Harlow        │
    ''│ Updated: 11/27/2010        │
    ''│ Designed For: P8X32A @ 80Mhz        │
    ''│ Version: 1.0        │
    ''│ Copyright (c) 2010 Jay B. Harlow        │
    ''│ See end of file for terms of use.        │
    ''│ Update History:        │
    ''│ v1.0 - Original release - 11/27/2010.        │
    ''│ Modified version of Kwabena W. Agyeman's DS1307 Real Time Clock Engine                                                      │
    ''│ For each included copy of this object only one spin interpreter should access it at a time.                                 │
    ''│ Jay,        │
    CON
      #1, Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, Saturday
      #1, January, February, March, April, May, June, July, August, September, October, November, December
    CON
      #0, secondsRegister, minutesRegister, hoursRegister, daysRegister, monthsRegister, dayOfWeekRegister, yearsRegsiter, _ctrl, _tc, #31, _burst
    VAR
      byte time[7]
      byte datar
    PUB checkSecond
    '' │ Returns the cached second (0 - 59) from the real time clock.                                                             │
      return time[secondsRegister]
    PUB checkMinute
    '' │ Returns the cached minute (0 - 59) from the real time clock.                                                             │
      return time[minutesRegister]
    PUB checkHour
    '' │ Returns the cached hour (0 - 23) from the real time clock.                                                               │
      return time[hoursRegister]
    PUB checkDay
    '' │ Returns the cached day (1 - 7) from the real time clock.        │
      return time[dayOfWeekRegister]
    PUB checkDate
    '' │ Returns the cached date (1 - 31) from the real time clock.                                                               │
      return time[daysRegister]
    PUB checkMonth
    '' │ Returns the cached month (1 - 12) from the real time clock.                                                              │
      return time[monthsRegister]
    PUB checkYear
    '' │ Returns the cached year (2000 - 2099) from the real time clock.                                                          │
      return time[yearsRegsiter] + 2000
    PUB checkMeridiemHour
    '' │ Returns the meridiem cached hour (12 - 11) from the real time clock.                                                     │
      result := (checkHour // 12)
      ifnot(result)
        result += 12
    PUB checkMeridiemTime
    '' │ Returns true if the meridiem cached hour is post meridiem and false if the meridiem cached hour is ante meridiem.        │
      return (checkHour => 12)
    PUB checkTime
    '' │ Caches the current real time clock settings. Returns true on success and false on failure.                               │
    '' │ Call "checkSecond" to get the real time clock second after calling this function first.                                  │
    '' │ Call "checkMinute" to get the real time clock minute after calling this function first.                                  │
    '' │ Call "checkHour" to get the real time clock hour after calling this function first.                                      │
    '' │ Call "checkDay" to get the real time clock day after calling this function first.                                        │
    '' │ Call "checkDate" to get the real time clock date after calling this function first.                                      │
    '' │ Call "checkMonth" to get the real time clock month after calling this function first.                                    │
    '' │ Call "checkYear" to get the real time clock year after calling this function first.                                      │
    '' │ Call "checkMeridiemHour" to get the real time clock meridiem hour after calling this function first.                     │
    '' │ Call "checkMeridiemTime" to get the real time clock meridiem time after calling this function first.                     │
      time[yearsRegsiter] := bcd2bin( readClock( yearsRegsiter ) ) ' year
      time[dayOfWeekRegister] := bcd2bin( readClock( dayOfWeekRegister ) ) ' day
      time[monthsRegister] := bcd2bin( readClock( monthsRegister ) ) ' month
      time[daysRegister] := bcd2bin( readClock( daysRegister ) ) ' date
      time[hoursRegister] := bcd2bin( readClock( hoursRegister ) ) ' hour
      time[minutesRegister] := bcd2bin( readClock( minutesRegister ) ) ' minute
      time[secondsRegister] := bcd2bin( readClock( secondsRegister ) ) ' second
      return true
    PUB changeTime(second, minute, hour, day, date, month, year)
    '' │ Changes the current real time clock time settings. Returns true on success and false on failure.                         │
    '' │ Second - Number to set the second to between 0 - 59.        │
    '' │ Minute - Number to set the minute to between 0 - 59.        │
    '' │ Hour - Number to set the hour to between 0 - 23.        │
    '' │ Day - Number to set the day to between 1 - 7.        │
    '' │ Date - Number to set the date to between 1 - 31.        │
    '' │ Month - Number to set the month to between 1 - 12.        │
    '' │ Year - Number to set the year to between 2000 - 2099.        │
      writeClock( yearsRegsiter, bin2bcd( ((year <# 2099) #> 2000) - 2000 ) )
      writeClock( dayOfWeekRegister, (day <# 7) #> 1 )
      writeClock( monthsRegister, bin2bcd( (month <# 12) #> 1) )
      writeClock( daysRegister, bin2bcd( (date <# 31) #> 1) )
      writeClock( hoursRegister, bin2bcd( (hour <# 23) #> 0) )
      writeClock( minutesRegister, bin2bcd( (minute <# 59) #> 0) )
      writeClock( secondsRegister, bin2bcd( (second <# 59) #> 0) )
      return true
    PUB checkSRAM(index)
    '' &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;
    '' &#9474; Returns the selected SRAM value at the specified index on sucess and false on failure.                                   &#9474;
    '' &#9474;        &#9474;
    '' &#9474; Index - The byte location in SRAM to check. (0 - 30).        &#9474;
    '' &#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;
      return readRam((index <# 30) #> 0)
    PUB changeSRAM(index, value)
    '' &#9474; Changes the selected SRAM value at the specified index to the specified value.                                           &#9474;
    '' &#9474;        &#9474;
    '' &#9474; Returns true on success and false on failure.        &#9474;
    '' &#9474;        &#9474;
    '' &#9474; Index - The byte location in SRAM to change. (0 - 30).        &#9474;
    '' &#9474; Value - The value to change the byte location to. (0 - 255).                                                             &#9474;
      writeRam((index <# 30) #> 0, (value <# 255) #> 0)
    PUB pauseForSeconds(number)
    '' &#9474; Pauses execution for a number of seconds.        &#9474;
    '' &#9474;        &#9474;
    '' &#9474; Number - Number of seconds to pause for between 0 and 2,147,483,647.                                                     &#9474;
      result := cnt
      repeat (number #> 0)
        result += clkfreq
        waitcnt(result)
    PUB pauseForMilliseconds(number)
    '' &#9474; Pauses execution for a number of milliseconds.        &#9474;
    '' &#9474;        &#9474;
    '' &#9474; Number - Number of milliseconds to pause for between 0 and 2,147,483,647.                                                &#9474;
      result := cnt
        result += (clkfreq / 1000)
        waitcnt(result)
    PUB RTCEngineStart(dataPinNumber, clockPinNumber, chipEnablePinNumber)
    '' &#9474; Checks out a lock for the driver and changes the I2C Circuit pins. Returns true on success and false on failure.         &#9474;
    '' &#9474;        &#9474;
    '' &#9474; DataPinNumber - Pin to use to drive the IO data line circuit.                                                           &#9474;
    '' &#9474; ClockPinNumber - Pin to use to drive the SCLK clock line circuit.                                                         &#9474;
    '' &#9474; ChipEnablePinNumber - Pin to use to drive the CE clock line circuit.                                                         &#9474;
      RTCEngineStop
      dataPin := ((dataPinNumber <# 31) #> 0)
      clockPin := ((clockPinNumber <# 31) #> 0)
      chipEnablePin := ((chipEnablePinNumber <# 31) #> 0)
      if((dataPin <> clockPin) and (clockPin <> chipEnablePin) and (chipver == 1))
        lockNumber := locknew
        result or= ++lockNumber
      dira[chipEnablePin]~~                           'configure chip enable pin
      outa[chipEnablePin]~
      dira[clockPin]~~                                'configure clock pin
      outa[clockPin]~
    PUB RTCConfig
      writeClock(_ctrl, 0)                                  'clear write-protect bit
      writeClock(secondsRegister, readClock(secondsRegister) & %0111_1111)        'clear halt bit
      writeClock(hoursRegister, readClock(hoursRegister) & %0111_1111)          'set 24hr mode
      writeClock(_tc, 0)                                    'disable trickle charger
    PUB RTCEngineStop
    '' &#9474; Returns the lock used by the driver.        &#9474;
      if(lockNumber)
        lockret(-1 + lockNumber~)
    PRI setLock ' 3 Stack Longs
      repeat while lockset (lockNumber - 1)
    PRI clearLock ' 3 Stack Longs
      lockclr (lockNumber - 1)
    PRI readClock(register)
      return read(constant((1<<7) + (0<<6)) + (register<<1) + 1)
    PRI writeClock(register, data)
      write(constant((1<<7) + (0<<6)) + (register<<1) + 0, data)
    PRI readRam(register)
      return read(constant((1<<7) + (1<<6)) + (register<<1) + 1)
    PRI writeRam(register, data)
      write(constant((1<<7) + (1<<6)) + (register<<1) + 0, data)
    PRI read( cmd )
    'Read a byte of data per command byte
      setLock
      outa[chipEnablePin]~~
      writeByte( cmd )
      dira[dataPin]~             'set to input
      readByte
      clearLock
      return(datar)
    PRI write( cmd, data )
    'Write a byte of data per cmd byte
      setLock
      writeByte( cmd )
      writeByte( data )
      clearLock
    PRI readByte | i
      datar~
      repeat i from 0 to 7
         if ina[dataPin] == 1
          datar |= |< i     ' set bit
        outa[clockPin]~~
        outa[clockPin]~
    PRI writeByte( cmd ) | i
      dira[dataPin]~~              'set to output
        outa[dataPin] := cmd
        outa[clockPin]~~
        cmd >>= 1
        outa[clockPin]~
    PRI bin2bcd(dataIn) : result | tmp
    'Convert a byte of binary data to binary coded decimal
      tmp:= dataIn/10
      result := dataIn - ( tmp * 10 ) + ( tmp << 4 )
      return result
    PRI bcd2bin(dataIn) : result
    'Convert a byte of binary coded decimal data to binary
      result := (dataIn & %00001111) +  ((dataIn >> 4) & %00001111)*10
      return result
    DAT
    ' //////////////////////Variable Array/////////////////////////////////////////////////////////////////////////////////////////
    dataPin                 byte 29 ' Default data pin.
    clockPin                byte 28 ' Default clock pin.
    chipEnablePin           byte 27 ' Default chip enable pin.
    lockNumber              byte 00 ' Driver lock number.
    DAT
    ''&#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;
    ''&#9474;                                                   TERMS OF USE: MIT License                                                 &#9474;
    ''&#9500;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9508;
    ''&#9474;Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation   &#9474;
    ''&#9474;files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy,   &#9474;
    ''&#9474;modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the        &#9474;
    ''&#9474;Software is furnished to do so, subject to the following conditions:                                                         &#9474;
    ''&#9474;        &#9474;
    ''&#9474;The above copyright notice and this permission notice shall be included in all copies or substantial portions of the         &#9474;
    ''&#9474;Software.        &#9474;
    ''&#9474;        &#9474;
    ''&#9474;THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE         &#9474;
    ''&#9474;WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR        &#9474;
    ''&#9474;COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,  &#9474;
    ''&#9474;ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.                        &#9474;
    ''&#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;
    I modified it to the point of getting to work, I haven't flushed it out enough to warrent posting it to the OBEX...
    Jay
