Need Help With "USB to RS-232" Connection
Ok so the problem I face is that I have two BASIC STAMPS 2 boards, however they both have a "RS-232 serial" connection & I only have access to 2 computers that can program the boards. Only one has a RS-232 port and that same computer is older than I am (it's 20+ years) and running on Windows 95. Plus it seams to have a problem with random crashes & it will only save to floppys. Anyways the other computer I have is a 2-month-old Windows 7 laptop, the oly problem is that it only has USB ports and a few other ports that are not usefull for this project.
What I need help with is as follows:
- A schematic for a USB to RS-232 adapter, that:
- Will function properly with:
- And is simple to make (no hard to find parts like: IC's, ect...)
---OR---
A few links for some USB to RS-232 adapter cables.
THEY MUST BE UNDER $15.00 TOTAL (PRICE+TAX+SHIPPING to U.S.A. ZIP Code 18929)
THEY MUST WORK WITH BOTH BOARDS I HAVE (LINKS ABOVE IN PURPLE)
COMPATIBLE WITH Windows 7 (However Windows 7 does have "troobleshoot compatibilty" feature that seems to work well with older applications/programs)
I perfer stores that are very reliable (Amazon, eBay, ect.)
=THANK YOU=
=TECH GEEK=
btw can u post links to all the stuff u mentioned
I am having trouble finding anything related to computer ports, cables, adapters, computers, ect... that says "dataset ready"
When u said "dataset ready (DTR)"... did u mean, "Data Terminal Ready (DTR)" ???? <-- this is also a link to wiki artical
I think Mike was pretty clear in a previous post that the :
http://www.parallax.com/StoreSearchResults/tabid/768/List/0/SortField/4/ProductID/378/Default.aspx?txtSearch=usb+rs232
USB to Serial adapter from Parallax was the cheap and easy solution to the WIN7 to BS2 board connection.
With the old computer, it just sounds like the standard serial programming cable could be used.
Jim
Here is another one: http://cgi.ebay.com/USB-RS232-9-Pin-Serial-Converter-Cable-Adapter-D13-/320614587568?pt=LH_DefaultDomain_0&hash=item4aa61e5cb0
