Combining whisker and IR
I am fairly new to the boe bot, i just got mine in last week. I have been doing some of the sample codes in the book but i want to try and combine them.
Specifically, I am trying to combine the roaming with whisker and avoid table edge. I cant seem to make them work right. Can anyone help?
' variables
irDetectLeft VAR Bit ' Variable declarations.
irDetectRight VAR Bit
pulseLeft VAR Word
pulseRight VAR Word
loopCount VAR Byte
pulseCount VAR Byte
FREQOUT 4, 2000, 3000 ' Signal program start/reset.
DO ' Main Routine.
IR program
FREQOUT 8, 1, 38500 ' Check IR detectors.
irDetectLeft = IN9
FREQOUT 2, 1, 38500
irDetectRight = IN0
' Decide navigation.
IF (irDetectLeft = 0) AND (irDetectRight = 0) THEN
pulseCount = 1 ' Both detected,
pulseLeft = 850 ' one pulse forward.
pulseRight = 650
ELSEIF (irDetectRight = 1) THEN ' Right not detected,
pulseCount = 10 ' 10 pulses left.
pulseLeft = 650
pulseRight = 650
ELSEIF (irDetectLeft = 1) THEN ' Left not detected,
pulseCount = 10 ' 10 pulses right.
pulseLeft = 850
pulseRight = 850
ELSE ' Neither detected,
pulseCount = 15 ' back up and try again.
pulseLeft = 650
pulseRight = 850
ENDIF
FOR loopCount = 1 TO pulseCount ' Send pulseCount pulses
PULSOUT 13,pulseLeft
PULSOUT 12,pulseRight
PAUSE 20
NEXT
LOOP
[ whisker ]
IF (IN5 = 0) AND (IN7 = 0) THEN ' Both whiskers detect obstacle
GOSUB Back_Up ' Back up & U-turn (left twice)
GOSUB Turn_Left
GOSUB Turn_Left
ELSEIF (IN5 = 0) THEN ' Left whisker contacts
GOSUB Back_Up ' Back up & turn right
GOSUB Turn_Right
ELSEIF (IN7 = 0) THEN ' Right whisker contacts
GOSUB Back_Up ' Back up & turn left
GOSUB Turn_Left
ELSE ' Both whiskers 1, no contacts
GOSUB Forward_Pulse ' Apply a forward pulse
ENDIF ' and check again
LOOP
[ Subroutines ]
Forward_Pulse: ' Send a single forward pulse.
PULSOUT 13,850
PULSOUT 12,650
PAUSE 20
RETURN
Turn_Left: ' Left turn, about 90-degrees.
FOR pulseCount = 0 TO 20
PULSOUT 13, 650
PULSOUT 12, 650
PAUSE 20
NEXT
RETURN
Turn_Right:
FOR pulseCount = 0 TO 20 ' Right turn, about 90-degrees.
PULSOUT 13, 850
PULSOUT 12, 850
PAUSE 20
NEXT
RETURN
Back_Up: ' Back up.
FOR pulseCount = 0 TO 40
PULSOUT 13, 650
PULSOUT 12, 850
PAUSE 20
NEXT
RETURN
