soil moisture measuring
I am considering measuring the soil moisture for my garden using the vegetronics sensor. It appears this gives a signal from 0 to 3 volts, depending on the moisture level. Can anyone give me an idea how to program this into the bs2 and then give an output.
Jim
Jim
best
al
Ultimately it will come down to observing onset of stress in your plants and the point in voltage, VWC or kPa at which stress occurs. Trigger irrigation before it reaches that point, given other inputs.
With any sensor of this type it is important to keep the sensor itself in intimate contact with the soil it is measuring. Voids significantly skew the measurement.
