Will a IRF644 work instead of a IRF640B
For the IRF640B http://www.datasheetcatalog.com/datasheets_pdf/I/R/F/6/IRF640B.shtml
For the IRF644 http://www.vishay.com/docs/91039/91039.pdf
IRF640B is hard to find just one or two of them
I have the IRF644 already to use will it work
HCPL-817-36DE Avago Technologies Transistor Output Optocouplers 5000 Rms 50mA
RS1507M Rectron Bridge Rectifiers 15A 1000V
IRF640PBF Vishay MOSFET Power N-Chan 200V 18 Amp
I have power but still will not heat the gun I put a new gun still no heat
I found on Ebay a store in Germany that sells the power for it but it would cost about $50.00 to ship it to the USA
But the person that I send the Email told me the part # that I could use to fix the power board with
Also had a problem with the transformer pins and plug pins on board where bad
Wired transformer wires to the Power Board
The problem start about two week ago when I was using de soldiering station the temp would go 30* to 40* F higher than it was set for but that day it happen three or for time that day
A few day latter when I turn it back on NO Heat
This has happen before a few time before the temp would go 30* to 40* F higher than it was set for it this would happen once then start working ok agian and when you would use again another day it would work ok then it might be month or two before it would happen again
Now that I replaced all three parts and Repaired transformer wires it tracks the temp alot better than it has for a while
