MIDI Examples
Bob Lawrence (VE1RLL)
Midi Input:
https://forums.parallax.com/discussion/125994
Overview:
http://nagasm.suac.net/ASL/Propeller/20080312/MIDIinPropeller.htm
MIDI out Schematic:
https://forums.parallax.com/discussion/118144
MIDI Input and Output Schematics:
https://forums.parallax.com/discussion/98059/propeller-midi-circuit-plz
Synthesizer object with General MIDI sound
https://forums.parallax.com/discussion/111867
MIDI Expander:
http://forums.parallax.com/attachment.php?attachmentid=60054&d=1239629974
MIDI Expander Lightshow (zip)
http://forums.parallax.com/attachment.php?attachmentid=60228&d=1240218022
Sythesizer:
https://forums.parallax.com/discussion/126780
Sick Day Synthesizer:
https://forums.parallax.com/discussion/109220
Rainbow synthesizer: polyphonic, multitimbral wavetable synthesis:
https://forums.parallax.com/discussion/109498
Propeller Multimedia Board(MIDI Interface):
http://syso.name/wiki/index.php/Propeller_Multimedia_Board#The_MIDI-Interface
MIDI to LED:
https://forums.parallax.com/discussion/124019
Completed Propeller based MIDI projects
Computerized Pyrotechnic Firing System:
http://www.parallax.com/tabid/716/Default.aspx
https://web.archive.org/web/20130528053707/http://www.parallax.com/tabid/716/default.aspx
MIDIomatic:
http://www.parallax.com/tabid/711/Default.aspx
https://web.archive.org/web/20130208101131/http://www.parallax.com/tabid/711/Default.aspx
A few Objects to get started with:
MIDI in:
https://obex.parallax.com/obex/midi_in/
Full Duplex Serial
https://obex.parallax.com/obex/full-duplex-serial/
Example Code:
' Transmit MIDI. Sends two notes to an external sound module.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 6_000_000 ' Set it for whatever Xtal you have. I used a 6Mhz Xtal for the test.
midi_tx_pin = 16 'use any pin number you have available)
midi_rx_pin = 17 ' Not required to transmit. Use any pin you have available
OBJ
midi: "FullDuplexSerial"
PUB sendNote
midi.start(midi_rx_pin, midi_tx_pin, %0000, 31250) '%0000 = mode, Baud Rate = 31250
Repeat
midi.tx($90) ' Note On , (also %10010000)
Midi.tx(60) ' Note = C
Midi.tx(55) ' Velocity = 55
Waitcnt(clkfreq + cnt ) 'Delay
midi.tx($90) ' Note On , (Also %10010000)
Midi.tx(66) ' Note = C
Midi.tx(0) ' Velocity = 0
midi.tx($90) 'Note On
Midi.tx(79) 'Note = G
Midi.tx(55) 'Velocity = 0
Midi.tx(0) 'Velocity = 0
'I copied the pasted the code into the Prop IDE and except for aligning everything, it worked fine.
MIDI Coming To 12Blocks:
https://forums.parallax.com/discussion/118236
Prop MIDI on YouTube:
http://www.youtube.com/watch?v=OyBgHSvVgUY
Overview:
MIDI out Schematic:
MIDI Expander:
Sythesizer:
MIDI to LED:
MIDIomatic:
MIDI in:
Full Duplex Serial
Example Code:
CON
OBJ
PUB sendNote
Repeat
SER.start(0, 17, 0, 31250)
SER.tx(144)
SER.tx(60)
SER.tx(64)
That doesn't do anything.
Anyone know how to do this?
