Does rxtime or rxcheck corrupt the incoming string if you use it?
rxtime uses rxcheck, the latter returns either the oldest received character or -1 indicating that there isn't one. So if there is one then it consumes a character (by returning it to you). I assume you use said function in a simple yes/no manner which - if not handled properly - loses characters.
MsgTest:==debug.rxtime(100)
getstr(@command)
if strcomp(@Reset, @command)
do stuff
From what your telling me my string compare won't work too well.
Let's say you receive the string "fred\n" ('\n' being the end of the line/string). Depending on timing MsgTest will either be -1 (timeout) or 'f'. Then getstr will assemble the string "fred" or "red". So in case you didn't get the timeout you want to recover the missing/consumed character.
getstr looks like one of your methods, so why don't you pass in an extra parameter (i.e. MsgTest) which when -1 is ignored otherwise inserted into the buffer before the serial device is read again?
Sounds interesting, but for the life of me I can't picture how to implement it.
I'd help you but I'd need to see more code in order to do so. An example would be ...
VAR
byte command[16]
PUB null
if (MsgTest := debug.rxtime(100)) <> -1 ' got character
command[0] := MsgTest ' recover character
getstr(@command[1]) ' append remainder of string
do stuff
You can also add a new methode to the FullDuplexSerial object, which returns the number of waiting bytes in the buffer. This does not change the buffer.
PUB rxcount : count
'' Check for bytes in receivebuffer (never waits)
'' returns the number of bytes
count := (rx_head - rx_tail) & 15
What does your code look like?
getstr(@command)
do stuff
Thanks for the help.
Greg
VAR byte command[16] PUB null if (MsgTest := debug.rxtime(100)) <> -1 ' got character command[0] := MsgTest ' recover character getstr(@command[1]) ' append remainder of string if strcomp(@Reset, @command) do stuffGreg
Andy
