Current required for a Propeller MCU
I built a test circuit for Propeller, like the Protoboard.I ve read in the specification of Propeller that it required only 500uA for each MIPS and for the maximum MIPS can be 80MHZ/4*8=160MIPS, means that Propeller draw 80mA at most.We combine that with the EEPROM and 5V for pin 9 of VGA,total about 100mA so can i use a USB connector from PC to provide current and 5V and use LDO like AP1117 to convert to 3,3V to supply the whole board.
on how heavily you load the outputs.
Our new PoS board is running dual propeller chips, two 16 bit I/O
expanders a touch control chip, real time clock, 512K eeprom, Sd Card
and a digi pot off the propellers 3.3v supply and the idle current draw
is 75 ma for the first board and 77 ma for the other.
Thank you for your information.
I use one Prop(used 24 I/O pins) a AT24C512 eeprom with VGA port and 3 optocouplers, but now i want to test vga port so i loaded a program that affect only VGA pin (p16-P23) but no thing happen, so i wonder if there is not enough current.
7" color lcd display and led backlight were not connected. The boards draw around
550 ma in operation. The led backlight can draw 300 mA alone.
opps my bad,it is only few lines above,so the power source is not the problem for my VGA test :mad:
