I wonder is there any simple code to illustrate 2ways communication feature of 433MHz RF Transceiver besides the given sample code from Parallax
(433Radio2WayRX-V1.2 and 433Radio2WayTX-V1.2).
The sample code is provided on the webstore page for the product via links near the bottom of the page. Whatever's there is what's available although other products may have sample code in the various tutorials as well.
What are you looking for that is not illustrated in the existing sample code? What are you trying to do with the wireless transceivers?
I believe the CRC examples on the webstore page use bidirectional signalling, but I could be wrong.
I have two devices: Transmitter (Joystick) and Receiver (Boe-Bot). Each device has one BS2 and one 433MHz Transceiver.
The transmitter (Joystick) controls the movements of the receiver (Boe-Bot). While that happens, at the receiver end (Boe-Bot), I have also built an IR object detector such that it gives a 1 (no object detected) or a 0 (object detected). Then, I would like to send this 1 or 0 to the Transmitter (Joystick). Basically, I would to have a 2-ways communications between Joystick and Boe-Bot.
*Joystick - transmitting and receiving
*Boe-Bot - receiving and transmitting.
You will need to designate one end or the other as the "master". The master always sends first, then waits for a response from the "slave". Say the BoeBot is the master. It will first do the sync pulse needed, then send a character indicating whether there's an object detected ("D") or not ("N"). The PC or whatever is controlling the joystick would start by listening for a "D" or "N" from the BoeBot. Once it receives that, it would send a character or several characters indicating the joystick position(s). You didn't say what kind of joystick or what kind of data is produced by it. For redundancy, the PC should send the joystick data twice. The BoeBot would wait for this (with a timeout on the SERIN statement to help catch errors), compare the two copies and ignore the data if it's not the same both times. Use the sample code as your framework.
After the BoeBot sends its data it would reverse the direction (transmit / receive). The PC end would do the same (receive / transmit) and, when it switches to transmit, would have to put out its own sync pulse as described in the Transceiver documentation.
If you don't want to use a PC on the joystick end, you'll have to have some kind of microcontroller like another Stamp on the joystick end.
Main:
DO
HIGH Yaxispin
PAUSE 2
RCTIME Yaxispin,1,rcYtime
StartTransmitting:
HIGH TxEnable 'Enable transmitter
PULSOUT Tx,1200 'Send sync pulse to radio
SEROUT Tx, Baud, ["UUUU!", rcYtime.LOWBYTE, rcYtime.HIGHBYTE]
LOW TxEnable 'Disable transmitter
GetIRResponse:
SERIN Tx,Baud,600,StartTransmitting,[irDetectLeft,irDetectRight]
DEBUG CRSRXY, 2, 3, BIN1 irDetectLeft,
CRSRXY, 9, 3, BIN1 irDetectRight 'See the value stored in irDetectLeft and irDetectRight
LOOP 'Start at the beginning
T9600 CON 84
Inverted CON $4000 'Value for inverted serial format
Baud CON T9600+Inverted '9600 baud, 8,N,1 inverted
[ Variables ]
rcYtime VAR Word
rcXtime VAR Word
irDetectLeft VAR Bit
irDetectRight VAR Bit
[ EEPROM Data ]
[ Initialization ]
[ Program Code ]
Main:
LOW Tx
LOW TxEnable
DO
' Wait for preamble, then receive data and crc value
SERIN Tx,Baud,[WAIT ("U!"),rcYtime.LOWBYTE, rcYtime.HIGHBYTE]
Simple transceivers like the ones you have are not very reliable in terms of data transfer. That's why a CRC or other error checking is often used. With the Stamps, you also have the issue of timing. When a Stamp is not executing a SERIN statement, it's not receiving serial data. If one Stamp starts to transmit data and the other Stamp is doing something other than listening, the data will be ignored. Sometimes the receiving Stamp will misinterpret the data and start receiving incorrect data in the middle of a transmitted byte and not get back in sync until the next transmit attempt. For best results, transmit slowly (less than 9600 Baud) and use error detection and retries. Alternatively, use a device like an xBee or Bluetooth transceiver that takes care of error detection and correction for you.
Transmitter Side:
' {$STAMP BS2}
' {$PBASIC 2.5}
[ I/O Definitions ]
TxEnable PIN 14 ' Transmitter(27982)TR pin
Tx PIN 15 ' Transmitter(27982)DATA pin
Yaxispin PIN 7
[ Constants ]
T9600 CON 84
[ Variables ]
rcYtime VAR Word
LOW Tx 'Initialize transceiver interface
Main:
DO
HIGH Yaxispin
PAUSE 2
StartTransmitting:
GetIRResponse:
Receiver (Boe-Bot):
' {$STAMP BS2}
' {$PBASIC 2.5}
[ I/O Definitions ]
[ Constants ]
T9600 CON 84
[ Variables ]
rcYtime VAR Word
rcXtime VAR Word
[ EEPROM Data ]
[ Initialization ]
[ Program Code ]
Main:
LOW Tx
LOW TxEnable
DO
DEBUG HOME, "RCxtime = ", DEC5 rcXtime, CLREOL, CR,
"RCytime = ", DEC5 rcYtime, CLREOL
FREQOUT 10, 1, 38500
irDetectLeft = IN11
FREQOUT 8, 1, 38500
irDetectRight = IN9
IF (irDetectLeft=0 OR irDetectRight=0) THEN
HIGH 1
HIGH 0
HIGH TxEnable
PULSOUT Tx,1200
SEROUT Tx, Baud, ["!"]
SEROUT Tx, Baud, [irDetectLeft,irDetectRight]
PAUSE 2
LOW TxEnable
ELSE
LOW 1
LOW 0
ENDIF
LOOP
