COM2Propeller problem
Hi everyone, i'm new to this MCU.
I ve bought 3 Propeller MCUs and now make a programming cable.
I make one according to schema on Parallax website.
The first time i attached it to my PC and F7 it shows a messenger said that Propeller ver 1.....,but the next time i plug it in no MCU is recognized.
I used AP1117 to create 3,3V from 5V USB.
I have tested the serial communication by connecting Tx to RX and echo on unchecked but only Tx is blinking and no character on lower windows ( i do like in post #31 at http://forums.parallax.com/showthread.php?t=84805&page=2 )
when i use a multimeter to check the voltage on Tx and Rx i saw the Tx is approximately 3,1V and Rx is only 2,2V
Please give me some advice,thank you
If it sometimes recognises the propeller and sometimes not, then there could be a few things not right - eg a connection not properly soldered, or a power supply not filtered properly.
We should be able to get this working if we have a bit more information.
i will take some photos now and upload it
the world has many thing that can't explain >-<
Soldered or breadboard connections? Maybe a dry joint.
Good to hear it is working.
yes, a breadboard connection is loosen
