Building my own stamp?
Hi I'm thinking about building my own basic stamp project, but I have a few questions before i start ordering parts. I know that parallax sells the interpreter chips/resonators and the memory chips. I've been looking at the schematics for the the stamps and it looks like the SIN and SOUT pins run directly to logic level converting transistors so i'm thinking that whats going to the tx and rx pins of the interpreter chip is TTL level serial signals (it makes sense if they are just specially programmed pic16's). If i'm right about the TTL signals, then think i could use USB and an FTDI chip and I could connect the TTL level directly to the TX an RX pins of the Interpreter chip(otherwise i would have to add a max232 and add the transistors etc). I was just wondering if anybody has tried this or am I correct about the TTL level?
http://forums.parallax.com/showthread.php?t=114299
Robert
Thanks Robotworkshop but i would rather build my own custom form factor its not really going to be a "stamp" more of an embedded microcontroller.
thanks for the help I'm off to design now
