GSM modules
Has anyone tried connecting a GSM module to the propeller?
I'm planning on trying a project that uses a GSM module and I'm just wondering if anyone has done it before and on what module and what program they used. Is it a hard thing to interface?
All you need is a serial program to get started, then parse the incoming sentences for the data you need. I just looked for a $GPRMC in the data, skipped the following comma, and put the next 70 (IIRC) bytes in a buffer. I then extracted the location data I needed from the buffer. The same simple technique should work with other modules.
I think you missinterperted gps with gsm. I was looking more into this:ADH8066 GSM Module
(http://www.sparkfun.com/products/10138).
I'm not sure how to send AT commands to the device and I was wondering how to do it or whether anyone has a program that already does.
Edit: The goal of the project is to send a text message to my phone on where it is.
It's similar, though. You need the same serial routines to communicate with a GSM module. Transmit AT<CR> and you should get OK back. Then take it from there.
It looks like Jay has solved this for GSM type phones (SIM card). This is from a link in the wireless forum:
http://forums.parallax.com/showthread.php?t=107112
Now if only there were a Verizon solution....
