TV not working?
Well, i just got my new Prop demo board today. I installed the drivers and watched the demo program, then i went off to interface it to the TV. Well, i hooked up the composite video cable to the TV IN section and i uploaded the tv demo to the Prop. After messing around with the TV for a long time i could not get it to display the text in a consistent fashion. It just didn't work? I am not sure if i am doing something wrong or if the TV is not working the way it is supposed to? Is this a simple newbie mistake? I have used the Prop for near a year now and this is my first time using video(A little late, haha). Anybody have a step by step of interfacing the Prop to the TV?
1) Get some kind of Propeller board with a TV output
2) Download one of the TV demos into it
3) Plug the TV output into the video input jack of the TV
That's the way it's always worked for me, whether I've had a Demo Board or a Protoboard with the video circuitry copied from the Demo Board.
Check your video cable. Check that you have your TV set up properly and you have the cable plugged into the right spot.
While you're at it... I'd check the other components... it sure sounds like something is loose.
Bill
