High Power Relays
Hi all,
I'm just learning about the microcontrollers, and my electronics experience is a little limited. I'd like to control three line-voltage relays, and have been reading up to figure out how to do this, but I'm not sure I'm going the right direction.
I found this Panasonic 75-264VAC, 2A SSR: http://panasonic-denko.co.jp/ac/e_download/control/relay/solid-state/catalog/semi_eng_aqg.pdf
Spec's say the input is 5V with a 0.3k impedance. If I understand what that impedance means (and I'm doing my math right), it appears these SSR's will draw about 17mA each.
Can can anyone tell me if I have this right, and will the BS2p drive three of these relays?
Also can anyone explain what's purpose/difference between "zero-cross" and "random" with regard to relays?
Thanks for any help,
Tim
Tim
Distribute the SSRs among the groups of 8 I/O pins. Each individual I/O pin can handle about 20mA and groups of 8 I/O pins (P0-P7 and P8-P15) can handle about 50mA. Three SSRs come to about 17mA x 3 = 51mA which is OK, but borderline. It would be better to move one SSR to another group of I/O pins if all three SSRs can be on at one time. Keep that all in mind with other loads as well.
