Serial Communication — Parallax Forums
eduardomoraiseduardomorais Posts: 11
edited 2010-11-20 11:13 in Propeller 1
Hello everyone!
I have a question about how he could control a buffer in communication between the computer and parallax.
How do I compare to securely deliver information I'm getting the computer in the form of bytes, with a reference value?
Below is a code I made for the function of ascending desemprenhar LEDs according to comparison even. However it is not working properly.:confused:
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
OBJ
Parallax: "Nomad"
PC: "FullDuplexSerial"
PUB Main
Parallax.start(0, 0, 19_200)
PC.start(31, 30, 0, 9_600)
Repeat
dirA[16..23]~~
longfill(@rx_comando, 0, 4)
rx_comando := PC.RX
'My question is why this works
CASE || rx_comando
QPOS : !outA[16]
CLRP : !outA[23]
longmove(@tx_comando, @rx_comando, 1)
PC.TX(tx_comando)
waitcnt(clkfreq + cnt)
DAT
rx_comando long
tx_comando long
QPOS byte "08", 0
CLRP byte "28", 0
  • T ChapT Chap Posts: 4,245
    Hi Eduardo
    It would be easier to read the code if you can edit it and put brackets at the top and bottom of the code
    At the top of the code put the word "code" inside these brackets [ ] at the bottom of the code put the word "/code" in brackets. This way all your indention is retained.
