Best way to test various 110vAC loads
Any ideas on what's the best way to test a micro-based AC wall switch with various load ranges (20w thru 800w)? A brute force way of doing this is getting a bunch of lamps, all plugged into the same power strip, connected to the unit, and power each lamp on/off as required. But I thought that someone here may have experience with a more elegant / smarter way of doing this.
Andy
Andy
If V = 100 lets say and we "draw" 10A we are Useing 1KW .
now lets assume a FET has 0Ω on Resistance .
and 1MΩ off . we can now plot a graph of duty Cycle a to "effective" Resistance based on its ON time.. for simple math sake lets say 50% duty = 500KΩ . and so on and so forth .
and Mr OHMs law can kick in and volla digital load .
now You will need to assign a curve factor . Prop or BS2 can handle this. cause IRL the 50% will not be 500KΩ . , so a a scaling factor is needed ...
http://www.westmountainradio.com/content.php?page=cba
this little toy may give you some Insight ..
its for batts but the same idea applys
kwinn, I tend to agree, and that's the path I've taken, but thought there may be a simple.cheap device that does this simulation for us. In that case, is there a fixture that will do this elegantly/compactly? Maybe some sort of 6+ bulb fixture that gives an on/off switch for each bulb so that you don't have to physically screw/unscrew the bulb to test?
I have used "J type" or "T3 type" quartz halogen bulbs (approx 1/4" dia. x 4" long) with regular house light switches to make variable 120V loads. The bulbs are available in several wattage's up 500W and possibly higher. Makes for a simple, compact, and inexpensive load center.
