Electronic noise, difficult to understand Please Help.
I have a Basic Stamp 2 module near a contactor ( A big relay "K1" )
and each time the contactor is ON or OFF the Basic Stamp
reset.
The distance between the Contactor and the Basic Stamp is
5 inches and there is no electric contact between them.
The Basic stamp power supply I am using is very good ( 12 VDC, industrial , more than
$ 200 )
I tried more Basic Stamps and all have the same problem.
Please see the picture.
Thanks. Joe
reset.
$ 200 )
Thanks. Joe
A good example of this is to turn on the AM radio in your car to a weak station, then drive under high power electrical lines and you will hear noise on your radio. Even though the lines are high in the air.
This is called EMI...
http://en.wikipedia.org/wiki/Electromagnetic_interference
The solution to the "air" part of this problem is to surround the electronic device with grounded metal or in a metal can/container. Then the noise does not get through. Like this...
http://e-fab.com/images/circuit-board-shielding.jpg
And wires or circuit board traces can act as an "antenna" to this noise. So a solution to that is to use "shielded cable" which has a grounded metal outer layer like this...
http://www.l-com.com/images/cat6-shield-drain-wire.jpg
The shielding / metal surround is like a Faraday Cage...
http://en.wikipedia.org/wiki/Faraday_cage
Jim
which decrease the electrical noise when switching.
Is the programming cable connected to the stamp? It takes very little interference to toggle the reset line.
It may also be necessary to separate the two devices physically or shield them from one another.
Finally, even with a good power supply, a 0.1 uF or so capacitor right at the Stamp's 5 volt pins is a good practice.
