Timothy Swieter's TCP and web server demo
![Bean](https://forums.parallax.com/uploads/userpics/855/n505WZVEIPHT1.jpg)
I found on youtube that Tim has a UDP, TCP and web server demo.
I found the UDP demo on the Obex, but I cannot find the TCP or web server demo source code.
Anyone know where it is...
Bean
Bean
http://www.averydigital.com/products.html
Timothy uploaded both SPI and parallel versions of the driver to the Object Exchange, but the SPI version only has the UDP demo. Try the parallel version at http://obex.parallax.com/objects/615/ for the TCP and web demos.
David Carrier
Parallax Inc.
Does it make any sense with the Spinneret to use the SPI version of the driver? The extra pins used by the parallel driver are all wired up, and not using them doesn't allow them to be used for other things since they are not exposed on any jumpers or headers anywhere on the board. I ask, just in case I am missing something...
The SPI connection is there so that you can develop code using either interface. The Spinneret Web Server can be used as a development platform to evaluate the Propeller and W5100 chipset before developing a custom board. By sharing the pins with the parallel connections we were able to add the feature adding only a select pin.
The reason we didn't bring out the potentially unused parallel pins is more a matter of size and layout. We wanted to create the Spinneret Web Server at a very low cost in a small form factor using a two-layer, single-sided PCB. Bringing out the extra I/O pins would have added to the size and/or cost.
David Carrier
I hadn't thought about the Spinneret as a development platform to evaluate using the W5100 chip on another board. Now it makes sense why you set it up like that.
I thought two layer means double sided PCB?
I think he means single sided as far as components on the board.
Your HTTP Server demo is excellent and is so far the basis of my server code. It is working flawless.
There is a very minor typo on line 141:
If any of you have noticed that the user LED was not lighting - I use it as a non-PST error condition flag.
The LED pin should be 23 (both the LED and AUX2 are defined as 26 in v001)
http://obex.parallax.com/objects/download/aux/82/
Brilldea_W5100_TCP_Server_Echo_Demo_indirect_Ver001.spin
to
The top Spinneret is running the new code with the yellow user LED, the bottom one is running Ver001.
thank you Timothy
/michael
I agree with you on the pins for SPI vs Parallel and the abscence of jumpers.
I suspect Parallel is there if you need performance.
My plan is to write solely for SPI connectivity to rescue the Parallel pins (probably cut them at the prop QFP chip initially) and then make the case that future Spinnerets have a header that you can either jumper to the W5100 or tap off to "other" things ;-) This would be the logical next step for the Parallax product as the current version is simply too restrictive in it's current design (Phil, not to say it's not a good design - it certainly is sir - but it's a bit of a Camel (a horse designed by a comittee) trying to be everything for everybody and thus limiting is creative re-use).
