Bigger MoBo prototyping module — Parallax Forums
David BetzDavid Betz Posts: 14,530
edited 2010-11-27 05:38 in Accessories
I see the small MoBo prototyping module that Parallax offers. Does anyone offer a larger one that would be compatible with the Spinneret? I'm looking for one that can hold three 8 pin DIPs along with the accompanying bypass caps and pullup resistors. My idea is to build a module with two SPI SRAM chips and a SPI flash chip.
  • propn00bpropn00b Posts: 5
    edited 2010-11-26 19:59
    Just buy a perfboard from radioshack
  • schillschill Posts: 741
    The standard motherboard connector does not have pins spaced at 0.1". Using normal perfboard is possible but it's not as simple as just soldering a connector to it.
