I saw this at a show, I would bet $$ this is driven by a propeller — Parallax Forums
CassLanCassLan Posts: 586
edited 2010-11-18 17:34 in Propeller 1
http://www.cabletronix.com/pdf/st-f35testf.pdf
I came across this at a vendor, and a similar item in a different case at another vendor, each had the same firmware, I cant wait to see whats inside, I'm pretty sure its propeller driven.
This model was different because it had a multi-meter attached.
Rick
  • mparkmpark Posts: 1,336
    edited 2010-11-16 14:16
    Hey Rick! Where have you been hiding, man?
  • CassLanCassLan Posts: 586
    edited 2010-11-17 06:28
    I have been blessed by an unbelievable amount of work. :)
    I ordered one of those, I will crack it open when it arrives.
  • Nick MuellerNick Mueller Posts: 815
    edited 2010-11-17 07:02
    I would not bet on it!
    Just because it does video? Not argument enough to exclude a lot of other processors.
    Nick
    edited 2010-11-17 12:15
    Ok well here are some Pics of it open, and also a video.
    http://www.youtube.com/watch?v=-Am6sj4Cg3w
    I would appreciate anyones input on how to figure out if it is or isn't.
    They have scratched the info off the chip.
    Rick
    1600 x 1200 - 428K
    1600 x 1200 - 490K
    1600 x 1200 - 601K
    1600 x 1200 - 619K
  • W9GFOW9GFO Posts: 4,010
    edited 2010-11-17 12:25
    The amount that is scratched off is not enough to remove all the markings from the Propeller chips that I have.
    Rich H
  • jazzedjazzed Posts: 11,803
    edited 2010-11-17 12:26
    The video certainly looks "Propellery" ... the crystal is on the wrong side of the chip though.
    edited 2010-11-17 12:33
    well, i'm going to trace some pins and see if things line up or not.
  • wjsteelewjsteele Posts: 697
    edited 2010-11-17 12:40
    jazzed wrote: »
    The eeprom is also connected differently.
    One other thing I see odd is the way they grounded the case of the crystal.
    Bill
  • SapiehaSapieha Posts: 2,964
    edited 2010-11-17 12:41
    Hi CassLan.
    If You look from PIN1 marking this IC not use same pins for XTal, and XTal to Propeller not need capacitors.
    That already give that it is NOT Propeller
    CassLan wrote: »
    Rick
    edited 2010-11-17 12:45
    I think you guys are probably right.
    I'm sure all this thing does, could be done with a propeller.
    This tool was almost exactly what I wanted to do for one of the prop design contests.
    edited 2010-11-17 12:47
    The Dremeling of the chip details is quite common, it gets them lucrative returned service work. It was a "You're kidding" and put it back together moment, for us in the service department.
  • Nick McClickNick McClick Posts: 1,003
    I'm betting it's an atmega1284. The xtal is connected to pins 7 & 8. Pins 6 & 5 look like they're connected to Vcc & Gnd, too. Here's the atmega datasheet.
