2.1 mm, center-positive connector for DC power
All--
Do you know where I can find "2.1 mm, center-positive connector for DC power" as on the PDB or BOE? I have been searching Jameco to no avail. Is there a more common name for this component?
Thanks.
--Bill
Thanks.
--Bill
If not other places, try ebay:
http://cgi.ebay.com/5x-DC-Power-Jack-Plug-Connector-2-1mm-x-5-5mm-PP01-/400149054797?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item5d2abe054d
They are in both 2.1 x 5 mm and 2.1 x 5.5 mm and 9.5, 10 or 14mm shaft.
Very common and should not be difficult to find in a nearby store I think.
Panel mount "female":
http://cgi.ebay.com/2-1mm-DC-Power-Jack-Socket-Connector-Panel-Mount-PS01-/130453905288?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item1e5fa89f88
I keep at least 3 Male and 3 female on tap here .
coaxial barrle plug is common name too.
Thanks!
I ordered some of these from Jameco . . .
Why can't I post an inline link using this new forum? Is it me? (I wanted to make the word "these" hot, but I see no way to do it.)
EDIT: Looks like I figured it out!
--Bill
https://www.jameco.com/Jameco/Products/ProdDS/101178.PDF
As seen on picture it seems difficult to fix them to the PCB, the connection pins looks flat and probably needs very large holes compared to normal pins. I don't know.. maybe no problem at all.
That is a nice datasheet!
Yes, the pins are flat and I will have to perform a bit of surgery on the PCB to make it work. But, it appears Parallax used connectors with the same pins. If Parallax can do it, then I will at least attempt it!
I have quite a bit of experience butchering stuff to make it fit!
--Bill
Oh yes, I'm sure that won't stop your project :smilewinkgrin:
