LT1298 accuracy
As I'm getting closer to using Vref NOT equal to 5V I decided to start with this one...
Let's say we watch a 4-20mA current loop with a LT1298 12-bit A/D converter.
Suggested configuration includes 250 Ohm resistor that yields a 1 to 5V voltage drop across full current spec. Now, that allows for (4V of diff.voltage / (4095- ((1/5)*4095))) = 4/3276 = 1.22mV accuracy.
My question is:
Will I increase the accuracy (to 4V/4095=0.977mV) by first "expanding" 1-5V to 0-5V using a front-end OpAmp?
And the second one:
- How to apply a Vref and what is the optimal/suggested way of doing it with a LT1298?
- Will Vref = 4.095V be the optimal one as 1tick = 1mV accuracy with a Vin = 0 to 4.095V or there are some other preferred methods of dealing with voltages less than 5V span?
My question is:
And the second one:
In such a case - do you recommend to offset the opamp by exactly 1.000V ... or since its usually not rail-to-rail leave a bit of "slack" ?
And how much is that "slack" I wonder :-) in case I power opamp from 5V (Vcc)
p.s. A2D should be LTC1298 of course (not LT....)
btw. a very interesting observation about behaviour of LTC1298 with BS2 can be found here
http://forums.parallax.com/showthread.php?t=72993
p.s.2 When in doubt read the Data Sheet - which I did.... and found that I made a mistake in my original idea of adjusting Vref in LTC1298. You cannot do it as LTC1298 has both Vref and Vcc tied together. What I had in mind was related to its cousin LTC1286 that has a separate Vref pin
I gues that covers my attempt to "adjust" Vref for LTC1298... or does it?
But the 1st question still remains valid.
What's the effect on accuracy when scaling Vin=1-5V to Vin=0-5V ?
If you use the 1298 at Vcc=5V and scale the signal to 0 - 5V the accuracy (actually the resolution) is 1mV per bit of the original 4V signal or 1.22mV per bit of the 5V signal.
I am assuming you are using a micro to control this ADC so I would suggest offsetting the signal so the ADC reads 40 - 50 when the input signal is 1V and amplify it (x1 for LTC1286 & 4.096V ref, x1.25 for LTC1298 @5V Vcc. This way the micro can tell if the input voltage goes below 1V (less than 40-50) and it can also subtract the offset from the reading.
Exactly - my mistake as I didn't read its data sheet for looooong time...
May I rather call it an increased 1mV accuracy (up from from 1.22mV) as the 12-bit resolution is what I cannot change indeed :-)
It's BS2 and after using LTC1298 in the same configuration for the last 12 years only now to discover what Tracy Allen explained in 2003 on all the errors it might have caused.
Well, better late than never :-)
something like this?
Eliminate pots - I like it a lot! I'll try to remember to implement something along that line in my next project.
Thanks for your help.
