The next step would be to grab a couple of objects from the object exchange and test/modify working code.
You'll find a lot of objects there. Some are really advanced (graphics, servo, serial protocols) and some simpler. Look around, and start with the easy ones.
In doubt, ask the forum...
The following link has everything you need.
http://www.parallax.com/ProductInfo/Microcontrollers/PropellerGeneralInformation/PropellerMediaPage/tabid/832/Default.aspx
The propeller manual has a spin reference with explanations of what each command does.
Further, the PE Labs are an excellent way to get started with the propeller
Good Luck
Massimo
