Faster Baud
Hi all,
Working on a data logger project. I have it take measurements on a couple POTS, works great. Got my GPS in the mail recently, and having trouble working it into my project. The BS2 cant seem to handle 9600 SERIN at all, and 4800 accurately. The chip only goes down to 4800. At 4800, it can only receive about 50% of the NMEA sentence.
Found this thread, http://forums.parallax.com/showthread.php?t=123897&highlight=9600+baud , sounds like the BS2px can handle a higher baud.
Wanted to ask you guys before I plunk down more money. should I try the BS2px or goto a different controller?
Heres my project specs:
Receive a NMEA RMC sentence.
Measure at least 2 POTS.
Write data to a Thumb Drive (was going to try the Parallax USB)
And it needs to do all of this 2-5x a second.
Any thoughts?
Any thoughts?
I have a bias toward using a Propeller for any application where speed and buffered serial I/O seem important for success. You can use Parallax's USB Memory Stick Datalogger or you can use an SD card or microSD card directly for storing the data for transfer to a PC. The Prop can also read pots easily.
Neither has a true serial buffer so programming has to make sure the processor is waiting for the string when it comes along.
Are you sure the GPS will give readings at 5x a second? Not all GPS's have that high a repeat capability.
Cheers,
thanks guys.
it will do at least 4x/second hooked up to my laptop. i have restricted it to only NMEA RMC sentences and i just watch the time stamp as it comes in. i believe it will be ok at 9600 baud, but the chip goes up to 57000.
