The right power hook-up for the Spinneret?
I keep finding errors in the Spinneret Web Sever PDF #32203.
Its statements like this that lead to My uncertainty.
I plan to grab some power from My Prop Pro Dev Board. 5 volts or 3.3 volts,One or the other.
What voltage and what PIN should I supply power to?
I would like to take full advantage of the Spinneret.
Thanks in advance for any help!
Caution: If the Spinneret Web Server is powered from more a 4.0 to 9.0 VDC source, the same
voltage will be present on J1 and J6. Ensure that all connected devices are tolerant of the input
voltage.voltage will be present on J1 and J6. Ensure that all connected devices are tolerant of the input
I just clipped the end off of a RC servo extension cable (3 wires). One end is plugged into the Spineret, the other end (open wires) is connected to a 5v power supply.
Thanks for the reply Mike G
I have the Spinneret running on 5 volts supplied to J6/2
The Spinneret seems to be running fine.
Thanks Again
I hope this will help others starting out with the Spinneret.
