Easy question.... i hope?
Hey, y'all. After a long time delerbirating and trying to find alternative routes, i finnally bought a Propeller Demo Board..I can't wait to try playing with video(something i have yet to do), but i have one, perhaps obvious, question...The specs say that the board can be powered by a 6-9 volt source supplied by the barrel jack, but is there another way to feed power to the device? I looked at the header and i did not see one labeled "Vin" or something. Is there a header that you can supply power to? Or will i have to find a alternative power input? Thanks for the help.
RK
RK
http://www.parallax.com/tabid/768/ProductID/340/Default.aspx
If you're looking to supply +5V to the board, you could also just feed that into the power connector. The regulator is a low drop-out one and should put out around 4.5-4.8V with a 5V input. I think the only thing that's used for on the board is the PS/2 and VGA connector and the 3.3V regulator, so you should be ok with the 4.5-4.8V.
Yep... Mike has a tendency to do that a lot around here! :=)
Bill
