Contest entry: Wood Boiler & Wind generator system webpage
I have a wood boiler for heating my house. I plan on using the Spinneret Web Server for monitoring my boiler and my solar system. The plan is to data logger all the info from the boiler and the wind generator.
Things the server must do.
1. provide current data.
2. provide historical data
boiler Data needed
1. flue temperature
2. servo data
3. wood boiler supply and return
4. storage tank supply and return
5. zone status
6. outside temperature
7. data needs to kept for 24 hours
wind turbine data need
1. generator voltage
2. generator current
3. generator wattage
4. battery voltage
5. data needs to kept for 24 hours , 1 week , 1 month , 1 year
Things i have solved
1. Photobucket can be used for pictures
2. Google charts can be used for making custom charts
3. xbee's will be used for sending data from the boiler and wind generator both have propellers installed
Things that will be a struggle
1. I do not have much microprocessor experience
2. I do not have much web page experience
boiler Data needed
1. flue temperature
2. servo data
5. zone status
4. battery voltage
Or maybe I should say hot!
Wood Boiler is on my list of projects for 2011.
OBC
check this link
http://chart.apis.google.com/chart?chxl=0:|0h|1h|2h|3h|4h|1:|0|250|500|750|1000|2:|0|25|50|75|100&chxs=0,00AA00,14,0.5,l,676767|1,FF0000,11.5,0,l,676767|2,0000FF,11.5,0,l,676767&chxt=x,r,y&chs=1000x300&cht=lc&chco=FF0000,0000FF&chd=t:55,60,63,68,65,64,66,67,69,68,67,66,67,68,68,68,68,68,67,68,68,70,67,69,70,67,67,70,68,68,69,72,78,87,87,65,33,22,19,22,22,22,22,22,23,23,23,23,24,24,24,25,25,26,27,27,28,29,29,30,30,32,33,34,35,36,37,37,37,38,40,43,44,45,46,48,50,49,51,55,57,57,58,60,59,61,64,64,65,67,67,69,66,69,70,68,69,68,69,68,67,67,68,68,67,66,70,68,68,68,68,71,70,70,70,71,74,73,73,69,61,68,59,70,62,53,73,62,52,80,86,93,90,88,89,81,79,94,98,76,37,23,19,10,10,12,9,10,15,8,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6|99,99,98,92,91,88,83,81,78,78,77,76,74,71,70,68,67,66,65,62,62,60,61,58,57,57,56,54,54,53,52,51,51,55,71,91,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,94,86,79,75,70,68,65,64,62,59,59,60,58,57,56,56,54,52,51,51,50,48,46,46,45,44,42,40,41,40,40,40,40,45,46,50,52,47,47,45,35,40,25,31,22,0,0,0,0,0,13,27,36,41,58,85,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99,99&chdl=Flue|Servo&chdlp=l&chg=20,25&chtt=Flue+%2F+Servo
