Looking to weigh things
I am interested in weighing items from 2 oz to 5lbs or so and report the results back to a Linux-based server. I would like to use one of the Parallax processors as the middleware between the server and the weighing stations. I was wondering what sensors (cheap) could be used for this project and if someone could point me in the direction of any Parallax-based similar projects. Thanks.
Then you will probably need 16-20 load cells, their attendant drive and amp circuitry, and 2 or 3 8 channel 12 bit adc chips.
Then I would suggest using a prop to energize the load cells and two 8 channel ADC's to acquire the data.
Most load cells require 3-12V AC in and provide a 2-3mV/V AC signal out at maximum load. That is if you put in a signal of 10V AC in to a load cell rated at 5Lbs max you would get an output of 20-30mVAC out with a 5Lb load on it. You would need to amplify and rectify this signal to provide a DC level to the ADC.
It may also be possible to select the individual load cells by energizing them one at a time and having a single amp/rectification/ADC circuit.
