looking for AC connector on digikey
There are a million types of connectors on digikey, and I can't find the one I want.
I want the fairly standard AC connector like the ones you see on the back of power supplies (on a computer), and other AC applications. It's a three terminal socket, with a "D"-type shape.
Any help on a name, or a link to one on Digikey would be helpful.
Digi key part # CCM1401-ND
I forgot to mention, I would like PCB mount (90-degree). Any help there? Now that I have a name and category, I may be able to help myself.
Bob, most are panel mount due to stress placed on cords, which would tear apart a pcb. I have never seen one like you describe, that being said, someone is bound to show one.
Good luck
Like myself http://www.allelectronics.com/make-a-store/item/ACS-42/IEC-POWER-INPUT-RECEPTACLE-RT-ANGLE//1.html
In that case, you could resort to a good stress relief clamp on the cord and either hard solder it or a PCB mount screw connector like this http://www.allelectronics.com/make-a-store/item/TER-202/2-POSITION-PCB-TERMINAL-BLOCK//1.html
