getting started
I want to built my own starterkit but cannot find
a schematic for the USB connector/interface.
Does the propeller 3.3v I/O match with 5V TTL?
please help,
thanks,
please help,
thanks,
http://www.parallax.com/Portals/0/Downloads/docs/prod/schem/PPDB_A_Schematic.pdf
I might give you the answer.
JM
There are other threads that suggest that if what you have is a 5v-only device, it's reasonably safe to connect those to Propeller pins as long as you put a 1K resistor or so in series between the device and the propeller on each line you connect. It drops the voltage and limits the current enough to keep from blowing anything up.
