how to blow 1.3V light bulb with Boe-Bot Rev C circuit? — Parallax Forums
arien009arien009 Posts: 7
edited 2010-11-12 21:03 in BASIC Stamp
Hi, anybody can advise on the above? thanks.
    edited 2010-11-12 08:03
    Blowing things up is easy. Didn't you mean how NOT to blow a bulb? THAT takes skill.
    Please elaborate on your goal so we can help.
  • arien009arien009 Posts: 7
    edited 2010-11-12 20:31
    What i meant was that I need the Boe-bot Rev C to run through a series of actions before sending a pulse to a 1.3V filament light bulb attached to the circuit board to light brightly and blow the filament to simulate a blast. I am using the standard 4 x AA batteries battery pack (6V).
    How should I connect the bulb on the circuit board and just sending a 'High PIN' signal will do?
    The light bulb is likely to need more current (briefly) than a Stamp's I/O pin can provide. Look at Nuts and Volts Column #6 (look here) for examples of using switching transistors to control higher currents than a Stamp can provide.
