Does anybody know if Parallax is still planning to fix the broken SX links
Capt. Quirk
The last positive answer I received was 2 months ago?
Capt. Quirk
I see that www.piclist.com is now defunt, but www.sxlist.com is still alive and well. Supporting them may best carry on the survival of SX creativity.
At the Parallax store site, the Forum page still shows SX Forum and Hydra Forum. Somebody is asleep at the wheel. Changes in the Forum have to be coordinated with with the Store or new customer or even old customers may loose heart.
Addendum: I went to this page and didn't see any problems with the links. Which store page are you referring to. Link please?
http://www.parallax.com/tabid/392/Default.aspx
All these recent changes are getting very tedious to adapt to. Capt. Quirk needs to elaborate.
BUT...
At least the informational sticky that Capt Quirk created in the SX forum is complete trash.
The only 100% solution at this point would be for him to use my link conversion tool here to convert them by hand. It's unfortunate, since there are so many of them; but, by using a separate browser tab with copy and paste, it should go rather quickly. The only other solution would be for me to use the conversion too and convert everything from the original post in the old forum, which would mean that his subsequent edits will be lost.
Thanks for the tool Phil. I'll rebuild it
Wouldn't be easier for me to just add "inc" to all the url's. Then you guys could just use your converter to do everything at one time?
Bill M.
No, that would not help. The problem with using the converter is that it takes the old forum as input to rebuild the post in the new forum. If you've edited the post since the original migration, all those edits would be lost, and you'd have to do them over again. That's the reason that posts which were edited got skipped during the remigration: we didn't want to undo anyone's work.
http://forums.parallax.com/
(from this) "forums/default.aspx?f=7&m=173639"
(to this?) "showthread.php?p=633760"
I don't know, but it looks as though I could relpace "forums/default.aspx?f=7&m" with "showthread.php?p" and then convert the number on the end? (most likely not that simple?)
If not, It doesn't matter, I have the thread converted to a .spin file. The prop tool is doing a good job of keeping everything readable and organized.
