Help! Measuring the propeller Power Consumption?
Is there a direct way to measure the power consumption of the propeller using a multimeter?? (measuring the amount of current the propeller draw?) I want to be able to measure the power consumption when one cog is active and also when multiple cogs are active. Will the temperature of the propeller chip be higher when multiple cogs are active vs one cog active?? any advice is greatly appreciated. Thanks
Hoang
Hoang
Heat is a byproduct of power. It should be safe to assume that the more cogs that are running, the more current that is being used, and therefore, more heat that is being generated.
http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/PropellerDatasheet-v1.2.pdf
