Question about Spinneret documentation:
I see material under "Getting Started" that reads
I believe that second paragraph should read "To provide power from J6..." (not "from J9"). Correct?
I'll post a little list of corrections I think should be made to the documentation, probably in an hour or so. But that one seems kind of important.
There are three methods for powering the Spinneret Web Server, using either J1 or J6. To provide power
from J1, connect pin 2 to ground, and either pin 1 to 3.0 to 3.6 VDC, or Pin 12 to 4.0 to 9.0 VDC. When
providing power from pin 12, the voltage will be output on J6 for both power and I/O.
To provide power from J9, connect pin 3, labeled 'B', to ground and pin 2, labeled 'R', to 4.0 to 9.0 VDC.
The power from pin 2 will be used for the I/O voltage on pin 1 and it will be output on pin 12 of J1.
Pin 2 on J6 and pin 12 on J1 are directly connected, so power can be input on one pin and output on the
other. These pins also provide the output voltage for pin 1 on J6.
I would also add a footnote to the power specifications that if power is provided from J6 and if a daughterboard is plugged into J1, the power needs to be a regulated +5V (i.e. it cannot range from 4V to 9V). The reason is that some daughterboards have onboard logic or other circuitry that depends on a regulated +5V supply on this pin.
