basic stamp as a relay?
hi im new to basic stamp but i have a laser that i need to have turn on and off from a voltage from a sound card dac. the voltage can be made to be about 1.0 to 2.0 volts dc. if the vdc goes low(under 1.0) then i want the laser off and if it goes high(over 1.0) i want the laser to be on. i figured bs2 would be good for this because its fast as this is going to be used for blanking the laser and not showing jump lines between objects in the lasers output image.
any help would be apreciated
any links to this kind of docs would help too thanx
the only stuff for relays wasnt in pdf i downloaded
i have been able to mess around with the boe bot and learn a bit from it and the programming is streight forward.....if i can get it to work i may be able to get a chip that i can understand. i just want to see that laser blank for me:jumpin:
Basically, it 'triggers' when the input goes above what it recognises as 'High', and keeps that setting until the input goes below what is defined as 'Low'.
After 'triggering' the voltage can fluctuate as much as it want, as long as it doesn't drop below the 'Low' setting.
It's very useful for 'cleaning up' signals, and it's also a lot faster than doing it with a BS2.
The BasicStamp is useful and it can be attached to the output from the 74xx14 to monitor output if you want, but the 74xx14 is the workhorse you need to turn the laser on and off.
If you through the BasicStamp, you can get the effect up to a point, but you are likely to add significant delays and possibly add misinformation unnecessarily.
