Easy Bluetooth Module And J2ME Mobile Phone
Hi All,
I am able to send Data With Easy Bluetooth Module on BS2:
From BS2 to PC.
From PC to BS2.
From Mobile Phone to BS2.
But I can't Send Data From The BS2 to The Mobile Phone Using Bluetooth.
I have JSR-82 complaint Mobile phone - Sony Ericsson W705.
My BS2 Micro controller is hosted on Board of Eduction.
I wrote a Very Simple J2ME Server Application - Below.
And Also a Very Simple BS2 Code For the BS2 Micro Controller - Below.
I Would Really appreciate your assistance with this issue.
Al.
================[BS2 Code]================
' {$STAMP BS2}
' {$PBASIC 2.5}
RX CON 2
TX CON 0
Baud CON 84 '9600 Baud
'My Mobile Device Address
addy1 CON $00
addy2 CON $24
addy3 CON $ef
addy4 CON $1a
addy5 CON $89
addy6 CON $51
DEBUG CR,"Establishing SPP connection..."
SEROUT TX, Baud,[$02,$52,$0A,$08,$00,$64,$01,addy6,addy5,addy4,addy3,addy2,addy1,$01,$03]
PAUSE 5000
'Entering Transparent mode
DEBUG CR,"Entering Transparent mode...",CR
SEROUT TX, Baud, [$02,$52,$11,$01,$00,$64,$01,$03]
PAUSE 3000
DO
SEROUT TX, Baud, ["Hello From BT"]
PAUSE 500
DEBUG "Printed Now",CR
LOOP
================[J2ME Code]================
public void run()
String inputTxt = mInputBox.getString();
String resultString = "";
try {
resultString = DoWork(inputTxt);
} catch (Exception ex) {
showMessage("Error", ex.toString());
return;
showMessage("Do Work Result Value", resultString);
private String DoWork(String inputTxt) throws Exception
LocalDevice localBTManager = LocalDevice.getLocalDevice();
localBTManager.setDiscoverable(DiscoveryAgent.GIAC);
String hostString =
"btspp://localhost:0000110100001000800000805f9b34fb;
name=SerialPort;
authorize=false";
StreamConnectionNotifier myNotifier =
(StreamConnectionNotifier)Connector.open(hostString);
StreamConnection conn = null;
while (!done){
conn = null;
conn = myNotifier.acceptAndOpen();
if (conn !=null)
showMessage("Handle Request","Conn Accepted");
DataInputStream dis=null;
dis = conn.openDataInputStream();
/*Process Request....*/
return "Done";
From BS2 to PC.
From PC to BS2.
Al.
' {$STAMP BS2}
' {$PBASIC 2.5}
RX CON 2
TX CON 0
addy1 CON $00
addy2 CON $24
addy3 CON $ef
addy4 CON $1a
addy5 CON $89
addy6 CON $51
PAUSE 5000
PAUSE 3000
DO
PAUSE 500
LOOP
public void run()
try {
return;
String hostString =
name=SerialPort;
authorize=false";
while (!done){
conn = null;
if (conn !=null)
return "Done";
Looks like this should work.
I do see a typo that could be throwing off the compiler in your phone?
' StreamConnectionNotifier myNotifier =
' (StreamConnectionNotifier)Connector.open(hostStrin g);
'____________________________________________^__
Could you post the code that talks to the BS2 from your phone?
This might help indentify the problem.
