Lorenz attractor - help
Hi all
Im new propeller user and teaching basic programming
Is possible help me with basic FloatMath example ? specialy Lorenz attractor ?
(im using Arduino and any attractor programming not problem in arduino wire code)
Please help me - very very THANKS
Sorry my bad english
A := B + C
becomes
A := FAdd(B, C)
and
D := - E
becomes
D := FNeg(E)
If you have something more complex, you can either separate it out into individual operations or nest the functions calls.
A := (B + C) * (D - E)
becomes
A := FMul( FAdd( B, C ) , FSub( D, E ) )
Read the documentation that comes with the floating point library from the Propeller Object Exchange. It shows you the routines that come with each version of the library. FloatMath is written in Spin, so it's relatively slow. I recommend using one of the assembly language versions instead.
And little question - is possible convert floating value to integer ? (for controlling sound or lcd etc...)
example floating value 1.256
integer value 1256
not rounded like 1
thanks
MG117
Lorenz 3D fractal map and nokia 6100 lcd
Thanks previous help
