Video timing; New discoveries, improved synchronisation code. — Parallax Forums
Linus AkessonLinus Akesson Posts: 22
edited 2011-04-07 21:08 in Propeller 1
Hi!
I've been venturing into the murky depths of video generator timing, and discovered some new glitches and previously undocumented behaviour. The upshot is that I managed to write a 100% reliable PLL synchronisation routine. (The technique used in Chip Gracey's multi-cog video drivers is 99.94% reliable.)
Here's the code, and all the juicy details:
http://www.linusakesson.net/programming/propeller/pllsync.php
  • RaymanRayman Posts: 16,457
    edited 2010-11-02 11:49
    I'll have to take a look at this...
    I have a driver for 3-cog 6-bit color photos on VGA that I could never get the pixels exactly on top of each other with...
    Maybe your ideas will help with that...
  • jazzedjazzed Posts: 11,803
    edited 2010-11-02 11:53
    Great work Linus! Thanks for sharing.
    edited 2010-11-02 12:03
    Great work and excellent analysis - this should go into the FAQ.
    Hi!
  • KaosKiddKaosKidd Posts: 296
    edited 2010-11-02 12:17
    WOW!
    Awesome writeup! It really explained a number of things!
    Great Job!
    KK
    edited 2010-11-02 12:36
    I predict jitter coming out of some existing video code! Awesome work!
    OBC
  • RossHRossH Posts: 5,777
    edited 2010-11-02 16:26
    Excellent work! This explains a problem I had with my virtual VGA driver failing to sync at higher resolutions.
    Ross.
    edited 2010-11-02 17:19
    Long time no see Linus! Excellent analysis. FWIW, the multi-bit glitch manifests in other areas as well, e.g. when changing counter modes with a live frqx.
    edited 2010-11-02 17:50
    Thanks Linus - excellent work!
    edited 2010-11-02 18:02
    Don't know if the community noticed or it, but Linus created a Propeller assembler called "plasma" for Turbulence which happens to have an "include" directive :) and it is fully open source. The full capabilities of plasma are not clear just looking at the examples, but at least it allows sharing constant definitions among files.
    Linus, what else can plasma do? Share library routines? other?
    edited 2010-11-02 22:09
    Awesome analysis.
    Yes, I've got some code that doesn't work too. Can't wait to bang on this.
    Thanks Linus!
    edited 2010-11-02 22:18
    Great thanks! It's fun to read.
    Re: jazzed- Linus created a Propeller assembler called "plasma"
    plasma Info Here:
    http://www.linusakesson.net/software/plasma/index.php
    edited 2010-11-04 01:13
    This is certainly MUST READ information for anyone that wants to completely master video in the Propeller. It opens up a whole new view point of understanding what is usually just referred to as the "Counter + PLL".
    The power of having two PLLs interleave the pixels on different cogs is awesome - better pictures, high resolutions, more colors.
    edited 2011-04-06 00:53
    ' Synchronise cog PLLs. Here there be dragons.
                            ' http://www.linusakesson.net/programming/propeller/pllsync.php
    			waitcnt	sync_cnt, =$30000	' 3 ms
                            mov     VCFG, =%0_01_0_00_000_00000000000_010_0_11111111
                            movi    FRQA, #$10000000 >> 23
                            mov     VSCL, #1                ' Reload on every pixel
                            movi    CTRA, #%0_00001_111_00000000_000000_000_000000 >> 23
                            waitcnt sync_cnt, #0            ' Wait for PLL to settle
                            mov     VSCL, #65               ' Any power of two, plus one
                            ' The next instruction must not be a waitvid, and should
                            ' probably not be an assignment to VSCL either.
    Some idle thoughts. To be fair, as far as video related programming is concerned I guess I can let the name PLL sync pass (5 out of 8 isn't bad). OTOH it simply doesn't work for clock dividers 32, 64 and 128 (only the NCO feeding the PLL is in fact sync'd). Not too serious really.
    The other thing I don't quite get is the reload on every pixel. That's like self-inflicted damage and then complaining that it doesn't work properly. And changing only a single bit doesn't help. If you step back for a moment and look at it you'll realise that you change a register value the moment it's sampled. Single bit change or not you'll have a ~50% chance that it catches up one cycle later (than the other cog(s)). I checked and this'll happen more often than you think. Which may be OK for a particular use case but can (and should) be avoided.
    DAT             org     0
    entry           rdlong  delay, #0               ' clkfreq
                    shr     delay, #10              ' ~1ms                  (%%)
                    rdlong  cref, par               ' initial sync target
                    waitcnt cref, delay             ' sync cogs
                    movi    ctra, #%0_00001_111     ' PLL, VCO/1
                    movi    frqa, #%0001_00000      ' 5MHz * 16 / 1 = 80MHz
                    mov     vscl, #vref             ' 32 rather than the default 4K
                    movd    vcfg, #2                ' pin group
                    movs    vcfg, #%0_11111111      ' pins
                    movi    vcfg, #%0_01_0_00_000   ' VGA, 32 pixels
                    [COLOR="blue"]waitcnt cref, #vref*3[/COLOR]           ' PLL settled           (%%)
                    [COLOR="red"]waitvid zero, #0[/COLOR]                ' dummy to play it safe
                    [COLOR="red"]sub     cref, cnt[/COLOR]
                    [COLOR="red"]mov     vscl, cref[/COLOR]              ' transfer adjustment
                    [COLOR="red"]waitvid zero, #0[/COLOR]                ' latch adjustment
                    [COLOR="red"]mov     vscl, #user[/COLOR]             ' transfer user value
                    [COLOR="red"]waitvid zero, #0[/COLOR]                ' latch user value
    waitvid zero, #0                ' [COLOR="red"]dummy to play it safe[/COLOR]
                    waitvid zero, #0
    Admittedly this comment makes it sound like you could get away without it. Wrong. Reason being that there are 4 cycle waitvids and 4 cycle waitvids. The former is your ordinary/official (and useless) 4 cycle version. The latter - also useless - happens during frame stretches where a minimal waitvid is pushed back by one cycle and makes the frame look longer. However, the next hand-off stays locked to the grid (vscl[11..0]*n) which means it happens one cycle earlier in reference to the waitvid which would throw off all timing. Anyway, I just thought I should share this (after finding out the hard way).
    The solution listed suffers from jitter (frqa <> po2) given the right circumstances. A more solid version is listed in my [thread=126874]waitvid thread[/thread] (20110409 update).
