Px24 Hot?
I have a bs2px24 on one of milfords development boards, just running flashing leds on the output pins. The px24 is supplied by the 5v regulator on the dev board.
Should the processor chip on the px24 get quite hot?
Thanks & regards... John
The SX processor used by the BS2px is designed to run normally in temperatures up to 85C which could feel very hot to a finger touch.
Thanks for replying so quickly.
Regards John
From what youve told me, and whats in the datasheet (thankyou) it seems I havent been kind to my px24.
On this dev board each io pin goes through a 1k resistor to one segment of a ten segment bargraph display. I wrote a test routine which toggles each output in turn, in an endless loop. The problem is it runs so fast that the leds appear to be all on apart from the toggling one.
As I dont want to do any damage, I think I will change the value of the limiting resistor.
Thanks for all you help
regards John
