Please help: TEST instruction operands not interchangeable ?
Hi list,
Apologies in advance if I'm asking something stupid/obvious, but I'm quite new to the propeller and this problem has been driving me crazy for some days now (until I found it). I connected a SPI SRAM (23k640) chip to the propeller, using the SPI ASM object (http://obex.parallax.com/objects/431/). It worked without problems. Then I tried optimizing the SPI object (I need more speed) and couldn't make it work, I was always reading "0" from the RAM. After a lot of debugging, I traced the problem to a "test" instruction. The problem is reproducible with the original SPI ASM object too: if I change this line (in red below):
with this line:
the code doesn't work properly anymore.
I looked through the manual, but I can't find any reason for the TEST instruction to work differently when its arguments are interchanged. It should just do a logical AND of its arguments and then set the carry flag, so why does the order of the arguments matter? I know I'm missing something painfully obvious here, but what is it ?
Thanks for your help.
MSBPRE_ '' Receive Data MSBPRE MSBPRE_Sin [color="red"]test t1, ina wc[/color] '' Read Data Bit into 'C' flag rcl t3, #1 '' rotate "C" flag into return value call #PreClock '' Send clock pulse djnz t4, #MSBPRE_Sin '' Decrement t4 ; jump if not Zero jmp #Update_SHIFTIN '' Pass received data to SHIFTIN receive variable
with this line:
MSBPRE_ '' Receive Data MSBPRE MSBPRE_Sin [color="red"]test ina, t1 wc[/color] '' Read Data Bit into 'C' flag rcl t3, #1 '' rotate "C" flag into return value call #PreClock '' Send clock pulse djnz t4, #MSBPRE_Sin '' Decrement t4 ; jump if not Zero jmp #Update_SHIFTIN '' Pass received data to SHIFTIN receive variable
What happens is that there's actually cog memory underlying all of the special registers and there's special hardware that substitutes a particular hardware register for particular cog memory locations. There's one set of special hardware for the source field and one set of special hardware for the destination field regardless of the instruction itself. Instruction fetches always come from cog memory ... there's no special hardware for that.
When you put INA in the destination field, you're referencing the "shadow memory" location that underlies INA, not INA itself.
